Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 29th October 2011, 12:05 PM   #11
Treybal is offline Treybal  Chile
Hello
I'm just finish assembling my tubelab simple se:
http://img803.imageshack.us/img803/9162/etapa5.jpg
This is my very first amp proyect, and after reading as a noob, and see the wiring page at the tubelab's site don't know how to wire this in pentode mode.
I think that perhaps connecting R18 and R28 to the B+ would do, but i'm totally unsure, this idea comes from wikipedia's deffinition of pentode mode.
So, how can i make that connection?
Today i'll get all the transformers from a local shop (custom made) and the choke.
Thanks in advance
Roberto.
Old 4th November 2011, 03:26 AM   #12
w5jag is online now w5jag  United States
I don't have a board in front of me, but from memory T3 Pri:2 and T2 Pri:2 should be jumpered to T3 Pri:1 and T2 Pri:1 for triode operation, or T3 Pri:3 and T2 Pri:3 for pentode operation. It is much easier to get the amp running in triode configuration.
I've been running my SSE in pentode mode for more than a year with good results, mostly with low screen voltage sweep / rf tubes, with good results. I have also used the EL34 with good results, albeit at relatively low screen voltages.
Be advised that, imo, pentode mode does require more negative feedback than the onboard cathode feedback can provide, at least in my setup. Without negative feedback, the frequency response will be skewed to favor the high frequencies,
More can be found in the 6146 in the SSE thread, if you are interested.
Win W5JAG
Old 4th November 2011, 11:42 AM   #13
Thanks, i'm gonna start with triode mode to get the amp running. I'm doing the basic configuration with a 375-0-375 power transformer, so i could get a >400 V B+, perhaps thats not provide low screen voltage, what's your low screen voltage and your B+?
EL34 pentode output in SSEHide this!Advertise here!
how to connect an EL34 pentode into a triode and 100ohm resistor between plate and g2 jarthel Tubes / Valves 15 26th October 2013 03:44 PM
EL34 Pentode in Push-Pull! Guijs Tubes / Valves 68 13th February 2013 09:08 PM
Suitable output transformer for SSE? Pilsern Tubelab 5 21st June 2011 05:44 AM
El34 SE pentode alexmoose Tubes / Valves 1 18th July 2006 08:26 PM
EL34 in Pentode Class A? ray_moth Tubes / Valves 7 24th March 2004 06:31 AM
Copyright ©1999-2017 diyAudio
