Tubelab SE - XLS tubes - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 29th August 2011, 08:57 AM   #11
jrobson is offline jrobson  South Africa
I don't mind looking for something, as long as it's available and I agree for the price it's excellent value, I've been through the tubelab site a few times finding information here and there which has been a great help in understanding how everything works.
Thanks I won't go too high on the voltage
Thanks, jpeg, great help with the wiring and caps, I was just wondering if there was a specific reason other than size, I can fit motor runs I think for the most part
Old 29th August 2011, 09:11 AM   #12
I don't want extra power as in watts just more "torque" for the low end if that makes sense
Reviews have suggest the XLS have just that, but the problem with Internet reviews are that they are of course free... lol.
Old 29th August 2011, 10:09 AM   #13
Sorry for being a little thick, but from the tubelab site it says the 6.3V doesn't have to be CT for the 300B tubes, how would one wire this up?
Old 30th August 2011, 05:49 AM   #14
Jpeg is offline Jpeg  United States
First you would want to set the board jumper as shown here.
Final Assy
And you would want to hook one 6.3v lead to T8, and the other to T7. If you have no center tap you would leave out T6. If you do have a center tap that goes on T6.
The idea is if you use both 6.3 volt leads, you get 6.3 volts (in this case regulated down to 5 volts by U1) but if you were to only conect to one of those, and the center tap, you would get 3.15 volt instead. This make the transformer more versitile.
Hope this helps.
Old 30th August 2011, 07:21 AM   #15
Thank you again
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 03:16 AM
FS: Tubelab SE board, components, Mundorf caps, and tubes sbelyo Swap Meet 6 21st April 2011 04:10 PM
Tubelab SE for other tubes Nikon1975 Tubelab 1 16th February 2010 06:52 PM
Tubelab SE with 45 tubes only operksoy Tubelab 13 15th December 2009 07:16 PM
tubelab se DimZ Tubelab 58 20th January 2009 01:47 PM
Copyright 1999-2017 diyAudio
