Tubelab SE checkout shows -300V Bias voltage? - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 25th August 2011, 02:11 AM   #11
dagerman's Avatar
Me again...
Amazing what a good night's sleep can do...
Woke up this morning and just looked at my breadboard setup while sipping coffee when I saw that I didn't have my speakers grounded...
Had to run to work, but just addressed this little oversight and, voila, there is music! But...
My B+ is still at around 440V. The 300B look healthy, no glowing other than that of the filament.
Now I have to figure out whether to
1.) find another PT with a more appropriate voltage, or
2.) try a different rectifier tube (any drop-in replacement suggestions?), or
3.) scratch the 300B for now and convert board and iron for 45s
Besides that, it doesn't sound very 'clean'. I don't really know how to describe it other than a mix between foggy and almost scratchy; kind of like a speaker that has a broken cone foam (mine don't...).
As of now, NO comparison to my Simple SE build sound-wise.
There are 10 types of people: Those who understand binary and those who don't.
Old 25th August 2011, 02:45 AM   #12
w5jag is offline w5jag  United States
2) Of the drop ins, a 5W4 has the most voltage drop - probably around 60-65 volts, but is only good for 100 ma or so; NOS 5Y3 will drop 55-60 volts and is good for 125 ma; 5R4 will drop a bit less than 5Y3 and you probably don't need to worry about its current limitations. Be advised that the Sovtek 5Y3 is not a 5Y3 - it's more like a reduced current 5V4.
A better way might be to remove the first capacitor in the power supply and use choke input - an LC power supply instead of CLC. That's how I ran my TSE.
Win W5JAG
Old 25th August 2011, 04:00 AM   #13
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
You should be able to drop that 40V by reducing C4. Try 10uF or lower. Are you using a choke?
Old 25th August 2011, 05:01 AM   #14
dagerman's Avatar
I already went down to 4.7uF for C4 without seeing much effect.
Yes, I use a Hammond 193J choke. I haven't yet measured PT output AC voltage and haven't tried the 125V primary yet. I'll do both as soon as I get the time, which probably won't be before Friday.
As always, thanks for your helpful suggestions. I still have a lot to learn...
Old 25th August 2011, 02:08 PM   #15
rknize's Avatar
Have you ever used PSUD? You need to drop it more. The TSE doesn't draw all that much current overall. Try 3.3uF.
Old 25th August 2011, 02:16 PM   #16
dagerman's Avatar
Russ, four out of three Germans are bad at math and theory... I am two of them.
No, I haven't used any simulation software recently. A little bit of Spice in school a long time ago. That may be a good way to learn, too, if that stuff runs on Mac or in a VM. I'll definitely try it.
Having said that, I couldn't help but try the 125V primary tap after my post last night and I am down to 395V. The distortion seems to be gone, too.
More testing and simulations to come.
Old 25th August 2011, 06:04 PM   #17
dagerman's Avatar
I just downloaded PSUD2 and played around with it for a bit, plugging in my transformer and CLC components. The simulation seems to match reality pretty closely. This is going to be a really helpful [learning] tool for me, thanks very much for pointing it out, Russ!
And thanks to the generous soul that spent time designing & implementing this tool and making it available, wherever you are!
Can't wait to get home today to spend some time listening to the amp and play with the bias a little bit more.
THANK YOU for all your help and guidance, the newbie appreciates it very much!
Stefan
Old 26th August 2011, 12:42 AM   #18
rknize's Avatar
Its a great tool. I originally ran the TSE with a different power transformer that i had kicking around. I removed that cap completely for an LC filter. Other than some buzz from the choke, it worked well.
Russ
Old 27th August 2011, 02:45 AM   #19
dagerman's Avatar
Default All checks out, but distortion at higher volume
So, after a couple of weird events (R3 silently died, one of the two 5824s with it), everything checks out. B+ is around 390V, bias set to ~70ma for now and pretty stable.
Sound is good, but not as good as the Simple SE built earlier this year. Maybe I a just got used to tube sound...
But, when turning up the volume while feeding a sine signal, at about 3/4 of total volume, the output shows a distortion. It doesn't look like clipping, but when playing music, it doesn't sound good at all.
Also, I noticed that the current across one of the 300B grid resistors seems to go up quite a bit at higher volumes (>100ma), which seems strange and can't be good for the tube.
What does an output signal form like this indicate, is this to be expected?
Old 22nd November 2011, 01:53 AM   #20
jrenkin is offline jrenkin  United States
Any updates on this? I am too curious.
tubelab sse checkout zxx222 Tubelab 6 5th January 2015 10:37 PM
help with tubelab SE checkout evanc Tubelab 2 28th March 2011 11:42 PM
Tubelab SE bias current keep on rising drazmanithnin Tubelab 13 7th March 2010 03:53 PM
Tubelab SE Driver Bias Help SGregory Tubelab 2 3rd January 2010 10:21 PM
Final checkout problems with Tubelab SE Mazuki Tubelab 11 21st June 2009 12:50 AM
Copyright 1999-2017 diyAudio
