Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 12th August 2011, 05:57 PM   #1
Green77 is offline Green77  Sweden
Default Psu tubelabse
Hi all!
Since my power transformer only puts out 300 v i used SS diods insteed of tube. I used the buv26e.
My sound have been ok, but it have been a bit dist in the song, but i didn't hear it from the instruments...
Today i put 2 caps 22nF parallel with the diods. 75% of the dist sound disappered
Anyone know how to kill the rest?
Thanks //Daniel
Old 16th August 2011, 04:24 PM   #2
boywonder's Avatar
buv26's appear to be power transistors........
What are you using for SS diodes?
You may want to try Fairchild 8A 1200V stealth diodes or similar and bypass them with your 22nf caps.
or some UF4007's with bypass caps for very little $$.
Old 17th August 2011, 08:46 AM   #3
My bad. BYV26e is the diods..
Old 17th August 2011, 07:13 PM   #4
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
It's a bit hard to say what might be going on without some sort of measurements. If one pursues the theory that bypassing the diodes reduced leakage flux from your power transformer, maybe bypassing the heater rectifiers will improve it further? What is the VA rating of your transformer? Does it get very hot? What is your chassis layout like? What is the chassis made out of?
Old 17th August 2011, 08:13 PM   #5
Power transformer is a Hammond 372jX. 243VA and it's not getting hot..
My chassis is made from steel. I can upload some pic's later in the week..
Around 2 weeks from now i can have a scope home and "see" if there is some problems with B+..any idea?
Thanks //Daniel
My TubelabSE is broken :( Green77 Tubelab 8 9th June 2011 05:24 AM
TubelabSE with DN2540? Green77 Tubelab 2 26th December 2010 09:45 AM
tubelabSE with 300b Green77 Tubes / Valves 18 13th December 2010 06:59 PM
Possible causes for TubelabSE failure Binaural Tubelab 16 8th June 2010 12:50 PM
TubelabSE bridge? huskydawg9 Tubelab 4 5th May 2010 12:27 AM
Page generated in 0.08079 seconds (73.24% PHP - 26.76% MySQL) with 10 queries
