| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
Dear All,
I'd like in my new Tubelab SE to reduce the voltage for the power drive to 200V to limit the heat consumption. The question is: how much current should I make available ? I tried to measure, but it looks like the current drain is almost zero. Thanks, Davide |
#2 |
The average current drain is set by the resistor from the source of the fet to the negative supply. I usually aim for 5 to 10 mA to limit dissipation in the mosfets. If your positive voltage supply is lower, then you can increase the current to improve the dynamics a bit. I have found no benefit to going beyond 20 or 25 mA. These current numbers are per channel.
For my test amps, I use an isolation transformer with two 120 volt secondaries which I put in series. With a bridge rectifier and filter I get a +/- 160 volt supply for PowerDrive. That works well.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#3 |
Thanks!!! I will be using the regulator from diyhifisuppy, that has -120v supply. For the positive suppy of the powerdrive i will use a secondary winding of the main transformer. As I will have it custom made, i will request 50mA 150v. That should make.
We will see what will come out. Davide |
#4 |
George,
Another question: what filament voltage are you aiming for the 5842 tubes ? I notice that with the current arrangement it is below 6.3 V. Do you think there is any advantage to run a separate filament supply for the drivers ? Thanks, Davide |
#5 | |
If you were building the ultimate amplifier with off board power supplies a good DC source for the 5842's might be a good idea. I did that in my 845SE amp which used a Tubelab SE for the driver.
#6 |
Will do like this.
Then I think it makes sense also to lower the AC for the 300B filament, so I reduce the heat production of the regulator. Am I correct ? Thanks, D. |
#7 |
As I am pretty flexible with the power supply at this stage I was thinking something like this.
The module that I am using needs the rectifier, so I am using the rectifier on board, mainly to hold the tube in place. The output of the module will be +400V and -120V. The B+ from the module should be mainly ripple free. I will have a separate supply CRC for the power drive. Now I can feed the B+ directly to the OT and feed the board with the power drive supply of around 200V. Like this the drivers and the power drive will share the supply, and I will reduce the heat also on the CCS. The disadvantage is that the driver will not have a supply as clean as the power tube, but I noticed that the CCS makes his own work to reduce ripple. Am I correct ? Does it make sense ? For the filament, I will use the on-board supply for the 300B, feed with something around 5.5VAC and a separate PSU feeding 6.3 V 0.8 A regulated to the drives. I will have an ACof around 7VAC. Please comment on my plan. Maybe I am missing something. Thanks, Davide |
#8 |
And the other disadvantage is that the drivers will be feed with a supply done with diodes rectification, not tube.
D. |
#9 |
Any input?
Thanks, Davide |
#10 |
So I think I will use the separate supply only for the mosfet. I set on 160 VAC 220uF 270R 220uF. Does it make sense here to have something like PP caps at the output, let's say 10uF or something smaller.
Additionally, I have two ammeter to connect instead of the resistors. Now they will be directly in the signal path. Should they bother me ? I plan to connect one pp cap for each channel right at the OT. I think this should mitigate any possible negative effect of the meter. Am I correct ? Thanks, Davide |
| Tubelab SE vs Simple SE | Pez | Tubelab | 25 | 29th October 2011 02:16 AM |
| Tubelab SE 2A3 _ Newbie question. | btran | Tubes / Valves | 14 | 21st November 2009 01:28 AM |
| Tubelab SE amp question | smbrown | Tubes / Valves | 8 | 21st September 2009 05:05 PM |
| tubelab se | DimZ | Tubelab | 58 | 20th January 2009 12:47 PM |
| Page generated in 0.10341 seconds (77.91% PHP - 22.09% MySQL) with 10 queries |
