diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubelab (http://www.diyaudio.com/forums/tubelab/)
-   -   SimpleSE heaven (http://www.diyaudio.com/forums/tubelab/193695-simplese-heaven.html)
cjkpkg 30th July 2011 12:38 AM
SimpleSE heaven
Funny how we come full circle many times in life.
The SimpleSE was the first tube amp I ever built. I have built many amps since the SimpleSE but somehow I always end up coming back to it.
I started out cheap with OPTs and tubes and this allowed me to experiment and evolve as I learned more.
This latest iteration is as follows:
Edcor XPWR155 PT
Edcor CXSE25-4-5K
SS rectifiers
Mullard 12AT7 type
Electro Harmonix KT90
Jantzen Z Silver coupling caps 0.47uF
All else is pretty much stock
B+ is running 469
L Power Tube 101mA
R Power Tube 103mA
This is really the most nifty sounding amp I have - it would be a tough choice between this and my heavily modified Pass F5. I guess it would depend on how much auxilliary heat I needed :D
rknize 30th July 2011 02:48 AM
Since building it, my SSE gets the most use out of all my tube amps.
cjkpkg 30th July 2011 06:34 PM
Here she is atop the F5...combined with the old Aikido it sounds really sweet.
Those KT90s are freakin HUGE! The plate assembly must be 0.50" taller than a KT88. No Glow on the KT90s whatsoever at the above specs.
https://lh5.googleusercontent.com/-6...2014.31.19.jpg
Sprags 11th July 2015 03:12 AM
Can you tell me why you chose the XPWR155 and CSXE25-4-5K as opposed to the XPWR035 and CSXE25-8-5K that were suggested on the TubeLab web site.
BillEpstein 6th August 2015 03:01 PM
Looks to me like the 155 omits the center-tapped filament supply and has 3, as opposed to 2 Amp 5V supply.
Both that horrrid blue, though :p
Resources saved on this page: MySQL 18.75%
