Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 24th July 2011, 12:06 PM   #1
Reidy- is offline Reidy-  United Kingdom
Default Simple SE 1 dead speaker & front tube getting very hot very quickly
Hi, I fired up my amp this morning to find no audio in the left hand channel
I have re-flowed all the sockets which has caused dry/poor solder joints in the past to no avail.
All the heaters are on and working, the front tube does get very hot due to it not doing any work
what parts and where should I test?
Is it possible for the MOSFET to have failed and what would the symptoms of that be?
Old 24th July 2011, 02:06 PM   #2
solved, turned out that a leg had disconnected itself as the joint was re-flowed
its always the simple things, but its all good now.
Simple SE Driver or Preamp Tube Structo Tubelab 0 22nd December 2010 06:35 PM
Hot power transformer in Simple SE? fandersen Tubelab 4 23rd September 2010 02:51 AM
Tube choices for Simple SE? BillEpstein Tubes / Valves 16 18th May 2009 04:35 AM
Help my transformer getting hot quickly darw82 Power Supplies 10 31st December 2005 03:27 AM
Dead simple tube circuit mrjcfreak Tubes / Valves 1 29th June 2004 09:31 PM
Page generated in 0.06119 seconds (66.95% PHP - 33.05% MySQL) with 10 queries
