Tubelab SE - Sockets off PCB? - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 25th July 2011, 09:37 PM   #11
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
The gate of the MOSFETs might need to have their gate stoppers moved close to the FET lead as well. They can oscillate too.
Old 25th July 2011, 11:25 PM   #12
dagerman's Avatar
Those look to be fine mounted on the bottom, if I can get them on the other side of the heat sink without the Q2/Q2 U2/U3 heatsinks colliding.
We'll see, thanks for the hint, I didn't know about the oscillation risk for the MOSFETs!
There are 10 types of people: Those who understand binary and those who don't.
Old 26th July 2011, 06:11 PM   #13
boywonder's Avatar
Originally Posted by dagerman View Post
The reason for the question is that I'd like to put it in a chassis such that the tube sockets are flush with the top.
Thanks for your thoughts!
Stefan
I built my Tubelab SE with the sockets flush with the top, and they are soldered directly to the PCB..........the PCB is hanging from the top deck with threaded standoffs. Everything except the tube sockets is mounted on the bottom of the PCB. The only thing that's a bit tricky is the filament regulator; just bend the leads and triple-check.
If your punched holes are a little off, you can still do this technique with slightly oversized chassis holes. When making them oversized, you have another chance to get them lined up properly, and the extra clearance will help with ventilation. My sockets fit quite snug so I added a couple of vent slots reasonably near the heat sinks. The amp has been working fine for months, no overheating of the regulator with 300B's.
Old 26th July 2011, 11:42 PM   #14
Tubelab_com's Avatar
Some builders have had success mounting the tube sockets off board, others have built radio and TV jammers. The 5842 / mosfet combination will oscillate if given a tiny chance. I would put the grid stopper right at the grid pin of the 5842 socket.
I have sometimes made socket extensions using brass tubing from a hobby shop to elevate the socket above the PC board. The tubing is covered with heat shrink tubing in this photo.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 27th July 2011, 05:16 PM   #15
dagerman's Avatar
Originally Posted by tubelab.com View Post
<...> others have built radio and TV jammers.<..>
I have been convinced. I will go with on-top sockets, on-back components and make the rest fit using the tips you all gave me.
THANK YOU!
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 03:16 AM
help with tubelab SE checkout evanc Tubelab 2 29th March 2011 12:42 AM
Need Help with Tubelab SE lth1 Tubelab 9 1st October 2010 10:06 PM
FS: tubelab simple SE pcb spgjmf Swap Meet 1 3rd March 2010 07:53 PM
tubelab se DimZ Tubelab 58 20th January 2009 01:47 PM
Copyright 1999-2017 diyAudio
