Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 26th June 2011, 06:20 PM   #1
BillEpstein's Avatar
Default SSE: Will going from 60 to 100uF PSU caps make an audible difference?
I built mine with 3-20uF Aerovox Motor Runs and it's become my everyday amp. Now I'm re-painting it (don't ask) and have the opportunity to add another 35uF Aerovox, although shoe-horned.
Do I really need the additional filtering? Will I hear it?
Old 27th June 2011, 05:32 PM   #2
tubelab.com's Avatar
I doubt that it will make a difference. The motor run cap works synergistically with the electrolytic to create a low impedance across the audio frequency range. With decent electrolytics it seems that any motor run of 40 to 100uF is all you need. I got some surplus 600uF caps and they didn't sound any different than the 80uF that I normally use.
You could always connect the extra cap into the amp with clip leads and try it before making the permanent change. This assumes that you already have the extra cap.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Audible difference between DTS and Dolby? arjscott Everything Else 3 1st February 2007 12:33 PM
Which caps make the most audible difference? TDWesty Solid State 5 31st January 2007 05:49 PM
60 Hz noise in modified Audible Illusions M2B mas Tubes / Valves 1 14th May 2004 03:59 PM
RC Tolerance -- audible difference r_s_dhar Analogue Source 6 11th August 2003 07:47 PM
Do expensive filter caps REALLY make a difference? mwmitchell Parts 11 1st July 2003 08:19 PM
Page generated in 0.06535 seconds (65.48% PHP - 34.52% MySQL) with 11 queries
