| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
Sorry for a dumb question. I am new to tubes and amp building. I completed breadboarding TSE and was going through checkout. George mentions to place a multimeter across filament supply for output tubes. Where exactly should I place the clips?
Thanks. |
#2 |
Where it says "2" on the board where output tube socket goes.
#3 |
Everharmonics, Thank you. It measures 5V at output tube socket. I set this up for 300B so I assume this is what I want.
Output grid voltage at R14 and R25 when set to most negative voltage are -89 and -295V respectively. Is this right? Why the difference? |
#4 |
#5 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Pins One & Four................at three-o-clock & six-o-clock as you view the tube from the bottom, Keyed at Twelve. 5V @ 1.2A draw.
__________________________________________________ __Rick........... |
#6 | ||
#7 |
I will check tube socket 1 tomorrow after work. I guess the abnormal voltage has its effect. right channel/speaker is not playing.
B+ is 372V at grid bias of 63mA on Right and 67mA in left. Rectifier is the brightest with bright orange, output tubes barely glow but when seen from top there is glow. No smell of burning plastic either. Don't know why there is o output from right. Any suggestions, I will look into it tomorrow. By the way, one speaker is way way way loud for a 15X26 foot room. By mistake I omitted volume pot, that thing goes in first. Connected a Denon DVD player with no volume control. Big mistake. |
#8 |
By the way I connected my old, in the closet, Klipsch synergy B1. This is a tiny bookshelf speaker, the detail is amazing, instruments crisp as crisp could be. I can't wait to get the second channel working.
George, Thanks for such a wonderful design made so simple. |
| Power suppy TL494 waveform | jol50 | Car Audio | 11 | 11th March 2010 08:21 PM |
| xbox power suppy dead | guitar_joe | Power Supplies | 3 | 2nd July 2008 04:03 AM |
| Parallel vs. series filament supply - or another filament idea | engels | Tubes / Valves | 11 | 13th May 2007 01:06 PM |
| series connection of filament in push pull output stage | nhuwar | Tubes / Valves | 42 | 10th February 2007 06:27 PM |
| krell kas power suppy hum | minh_827 | Solid State | 10 | 16th September 2005 01:44 PM |
| Page generated in 0.10124 seconds (77.94% PHP - 22.06% MySQL) with 10 queries |
