diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubelab (http://www.diyaudio.com/forums/tubelab/)
-   -   X2 cap for Simple Single Ended (http://www.diyaudio.com/forums/tubelab/189373-x2-cap-simple-single-ended.html)
bamph 20th May 2011 07:31 PM
So I'm finally getting ready to build my amp and I have a question. I am not using the circuit board -- though at this point I would have been finished months ago had I gone that route. Anyway, since I am using a turret board, I do have a bit of extra flexibility.
Should I use an X2 cap and resistor between the signal and power supply grounds and the chassis? I see Bruce did this on the OddBlock design and that in his design and construction tips he recommends it.
I am not aiming for an ultimate build, but the inclusion of these two parts would be cheap and painless.
Thanks for comments,
Ben
wushuliu 21st May 2011 07:02 AM
I have a resistor-cap filter from earth ground to chassis/star ground on my amp with no problems.
Copyright 1999-2017 diyAudio
