| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
Hello I am gathering the last few parts to start the building for my tubelab SE.
And my Question is : In the manual is said that the optional choke for the Tubelab SE is a recommended upgrade. There is also written that it need to be a 150mA choke. Can I use the Edcor CXC-10H-200mA or is this choke to large to use. My tubelab will run 300B tubes so I also need to order a custom Edcor power Transformer with line 230V to 640V at 150mA 6,3V at 4A en 5V at 2A. Is it a problem if the trafo is 640V and 200mA or not. Also I would like to ask if the Edcor Opt's are worth the money. Sorry for my Question but this will be my first DHT amp that I build and I still need a lot to learn. Kind Regards, Steven |
#2 | ||
#3 |
Steven: Your choke will work fine. Also check out the Edcor XPR131-240, that was a custom that rknize had made for the Tubelab SE. I'm using the 120V version for my Tubelab SE with 300B's.
#4 |
I live in Belgium where the current is 230v (231,5 when measured with a meter).When I look at the tranformer for Rknize the XPR131-240 it has 240v on it's primary will a 240v transformer work in my area without power loss. or do I have to order a higher output voltage such as 650 to 660V or is this not necessary.
Kind Regards Steven |
#5 |
It should be just fine.
#6 |
Ok Thank you for the information, I also have a small question about the bleeders on the board. These are all connected to the ground on the amp. But I live in a very old appartment at the moment and the whole place doesn't have grounds on the sockets. Now my question is will the tubelab SE bleeders work or not. And what can I do to make sure everything is Safe.
With Kind Regards Steven |
#7 |
Yes, they will work. Ground is all relative, so the caps will bleed down relative to the ground on the board. The safety ground ensures that the chassis remains at a safe voltage. This protects against some sort of insulation failure, such as the OPTs or power transformer. In this case, the safety ground provides a separate path so that any such short would blow the fuse.
#8 |
Thanks Russ for the answer as for the safety ground can i reduce the possibility for the OPTs and power transformer to bleed any voltage to the chassis by putting rubber insulators under the OPTs and power transformer.
#9 |
![]() By steventje123 at 2011-06-16 ![]() By steventje123 at 2011-06-16 ![]() By steventje123 at 2011-06-16 A Few Pictures From My Tubelab SE in progress I was planning to run 300B tubes on it but things are changed since I own a few pair of 45 Tubes. So this will be a complete amp running only 45 Tubes. Last edited by Steven123; 16th June 2011 at 03:31 PM. |
#10 | |
Single-Ended Tube Amp Kit |
| Mosfets for Tubelab SE? | mctavish | Tubelab | 46 | 14th January 2012 02:07 PM |
| Tubelab SE vs Simple SE | Pez | Tubelab | 25 | 29th October 2011 02:16 AM |
| Need Help with Tubelab SE | lth1 | Tubelab | 9 | 1st October 2010 09:06 PM |
| 46 and the Tubelab SE | w5jag | Tubes / Valves | 8 | 18th May 2009 07:52 PM |
| tubelab se | DimZ | Tubelab | 58 | 20th January 2009 12:47 PM |
| Page generated in 0.10984 seconds (84.20% PHP - 15.80% MySQL) with 10 queries |
