Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubelab Discussion and support of Tubelab products, prototypes and experiments |
#11 |
I've had reasonable success cleaning boards prior to reworking with a commercial spray flux remover and short bristle brush (similar to tooth brush), followed by rinse with isopropyl alcohol. (then an internal rinse with ethanol )
Careful with solderwick to clean/scrub excess solder and flux residue from eyelets - George's boards have quality plating, but not all can stand the prolonged heat from this process. I've had to patch over several foil lifts while working on mods to an old Jolida amp, but had to scrape like crazy to break the trace on George's SimplePP board to mod for series choke in power supply.
kinda burnt out - taking a break |
Thread | Thread Starter | Forum | Replies | Last Post |
Help with capacitor markings (pic attached) | scoob8000 | Parts | 22 | 8th June 2009 02:39 PM |
Stepped Attenuator Question (see attached pic) | LinuksGuru | Solid State | 0 | 14th December 2008 07:49 PM |
Help interpreting spectrum analyzer results (pic attached) | percy | Solid State | 5 | 28th August 2005 03:01 PM |
Crossovers - Exposed solder joints a fire hazard? | BAM | Multi-Way | 12 | 16th March 2003 06:56 PM |
New To Site? | Need Help? |
