Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 16th May 2011, 07:31 PM   #1
Horsebox's Avatar
Default PCB solder joints blackening after two week's use - pic attached
Hello again,
My last query for a while - I shall attempt to resist the urge to tinker further until the winter - thanks for all your help.
My SSE has been in service for just over two weeks now and has been running without problems. The PCB now has quite a bit of blackening at the solder joints, and it's particularly bad around the valve sockets (see picture). These solder joints were completely blemish free after soldering and before power-up (honest!).
Anybody else have the same thing, or know what the cause might be? I'm a bit worried that it'll get worse until something goes pop.
Cheers!
Old 16th May 2011, 07:40 PM   #2
Ty_Bower's Avatar
Originally Posted by Horsebox View Post
Anybody... know what the cause might be?
You didn't clean off the solder flux before you powered up the amp. Now the flux is baked dry from the heat of the tubes, and probably won't ever come off.
Don't worry, it should be pretty much harmless. I did the same thing on mine, and it looks like yours. I wish I had cleaned it before I played it, but I was impatient.
Click the image to open in full size. Click the image to open in full size.
http://i69.photobucket.com/albums/i4...E/P1140548.jpg
http://i69.photobucket.com/albums/i4...E/P1100584.jpg
Old 16th May 2011, 09:25 PM   #3
Horsebox's Avatar
Ah, I wondered if that might be the cause! I applied flux separately to the solder and it was difficult not to overdo it. I made a half-hearted attempt to remove obvious excess after soldering but the sharp edges made access hard. No doubt impatient too.
Will use the wife's toothbrush and a soapy solution next time.
Old 17th May 2011, 01:04 AM   #4
You may be able to scrape off the stubborn ones with toothpick or metal tweezers. Then use isopropyl (rubbing alcohol) on "Q" tips to remove the remaining.
Old 17th May 2011, 01:15 AM   #5
tubelab.com's Avatar
Yes, it's crispy fried flux. It's harmless and I don't bother to clean it off unless I am taking pictures of the board. There are commercial products that will remove it. I got one called "Flux Off" to clean up the boards for pictures. Laquer thinner will remove the green stuff, don't use it.
After the flux has hardened to the dark brown color, it is very brittle and much of it will crumble away with a little persuasion from an Xacto knife or small screwdriver.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 17th May 2011, 01:21 AM   #6
49 - for the 16th time
c2cthomas's Avatar
Hello Horsebox - take at look at this link for a look at how I have done this when slaughtering stuff together. Alcohol Dispensing Pump Bottle
The pump bottles are very handy but can get expensive. Take a look at beauty supply shops as the ladies use them to dispense acetone when doing finger nail jobs and they have the bottles for reasonable. Also - I prefer to use acetone for flux removal - if using alcohol use the denatured type rather than the isopropyl (however you Brit's might spell "isopropyl") i-so-pro-pall??? Isopropyl alcohol is commonly known as "rubbing alcohol" and contains water (H2O) which will cause corrosion to form down the road.
Hope this helps!!!
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 17th May 2011, 03:35 AM   #7
jcx is offline jcx  United States
wrong - acetone, other ketones can eat some common plastics, especially polycarbonate and polystyrene caps
isopropyl is safer, the 90% grade should be good for dissolving most organic residue
at worst I would carefully spot apply acetone only if and where the isopropyl wasn't working
water is perfectly fine on most assembed pcb - a 1st pass is a simple tap water/detergent cleaning with a toothbrush
distilled water, isopropyl rinses
the alcohol as a final rinse actually helps dry the board, parts, crevices by diluting the retained water and flows away more freely
still air blast, gentle heat or just leaving overnite to dry out any moisture can help
anyway distilled water is not a very good conductor if the board is properly clean
corrosion is only an issue if you still have conductive residue on the board
Old 17th May 2011, 03:43 AM   #8
c2cthomas's Avatar
This is all true - usually not a problem around tube amps tho. Still - I would go with the alcohol too.
Old 17th May 2011, 03:54 AM   #9
sofaspud's Avatar
I've heard some electronics fluxes can turn corrosive, but I've never experienced that myself. I've always used an old toothbrush and IPA. Running water for water-soluble flux. Followed by a compressed air blast. The OP's baked flux can probably be mostly rid of using a dental pick and the alcohol-toothbrush treatment.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 17th May 2011, 04:07 AM   #10
digits's Avatar
If acetone is used carefully, especialy BEFORE adding plastic components that are sensitive, it is superior to alcohol for this purpose.
Getting a good resin to coat your boards will seal in the clean!
Help with capacitor markings (pic attached) scoob8000 Parts 22 8th June 2009 02:39 PM
Stepped Attenuator Question (see attached pic) LinuksGuru Solid State 0 14th December 2008 07:49 PM
Help interpreting spectrum analyzer results (pic attached) percy Solid State 5 28th August 2005 03:01 PM
Crossovers - Exposed solder joints a fire hazard? BAM Multi-Way 12 16th March 2003 06:56 PM
Page generated in 0.11994 seconds (83.30% PHP - 16.70% MySQL) with 11 queries
