Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 12th May 2011, 07:15 PM   #1
wushuliu is offline wushuliu  United States
wushuliu's Avatar
Default SimpleSE Grounding Confusion
I have grounded my recent SimpleSE build according to wiring diagrams on the Tubelab site, but some researching on this forum has people saying to ground differently. I just want be sure I am doing this right.
I am using: an aluminum chassis, Triode mode, No CFB. I have drilleded a star ground lug near the IEC earth, with:
Each negative binding post wired to the lug
One audio input ground wired to the lug
IEC earth wired to the lug
OPTs screwed to chassis and so are grounded
Does this sound okay?
Also, I have an Allied PT coming. It has a gray shield wire. Do I wire this direct to earth or star ground or...
any suggestions appreciated, grounding always seems to be really complicated.
Old 12th May 2011, 07:41 PM   #2
nightanole is offline nightanole  United States
Put all grounds on one star ground, this includes power supply, output transformers, input rcas.
Earth ground the chassis
Inbetween the and the earth chassis lug, put this ground look isolator in:
Power Supply for Power Amplifiers
This puts the audio ground a few volts higher then earth so you dont get hum/noise.
So you got your star ground, connected to chassis ground, via 2 diodes (or 4 if you have a 20-35amp monolithic rectifier) a resistor, and a cap.
Here is another drawing:
http://farm4.static.flickr.com/3525/...62fe729f70.jpg
zero volt line= audio star ground.
SimpleSE Grounding ConfusionHide this!Advertise here!
Confusion about star grounding? semi932 Power Supplies 6 27th May 2010 04:47 PM
Need Some SimpleSE Help gasser-dude Tubelab 30 29th December 2009 12:12 AM
Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... EchoWars Solid State 37 3rd August 2008 08:50 AM
SimpleSE and me allyourzigg Tubes / Valves 8 1st August 2007 02:44 AM
LM3875 kit grounding, optimal grounding for separate amps and psu? findog Chip Amps 9 16th May 2005 09:27 PM
