Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 2nd November 2011, 03:03 AM   #11
Default values for choke
According to this article, when using a supplemental cap with the choke, the choke can be smaller (higher DC resistance, and lower current) as its main job is filtering the DC supply to the screen grids (<10 mA per output tube and <5 mA for the 12AT7 = 25 mA choke)
Chokes
Paul
Old 2nd November 2011, 03:03 PM   #12
Just for pure academics. In a perfect world with a 100,000 cap coupled power supply and class A, the choke would do almost nothing, since current would never change. A resistor would get the same result if it had the same resistance.
A choke coupled transformer needs a huge choke to handle the massive current changes ( or they growl). However George's amp is cap coupled. So what he recommends is what is needed, just enough current to handle the load. The motor run cap after the choke drastically cap decouples the power supply, so the transients are handled by the super low esr cap, instead sucking a current swing through a 150ohm resistor or choke before it gets to the ps cap.
Eyuda Motor Run Cap?? neonthecat Tubelab 3 5th May 2011 01:38 PM
Need a single ASC 100uF Motor RUN cap jmillerdoc Vendor's Bazaar 0 3rd November 2009 02:16 AM
SimpleSE - motor run cap specs astrodog Tubes / Valves 10 19th March 2009 02:23 AM
Source for 100uf motor run cap. audiobliss Tubes / Valves 3 31st July 2008 03:15 AM
motor run capacitor milen007 Parts 12 28th June 2008 05:49 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
