Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 25th April 2011, 06:02 PM   #1
jacko is offline jacko  United States
Default Question on Tube Sockets
Hi there,
I'm starting a build on a new Simple SE, and I would like to know if there are any sonic disadvantages to mounting the sockets differently. In the manual, the sockets used were PCB mounted ones. If I went with chassis mounted sockets say both octal sockets (power tubes) wired same distance away from the pcb, would this incur any degradation? I understand that alot of the diy'ers do point to point, but with the design of the pcb and it's very short distances, would I be looking at a major degradation or very very minute only.
Thanks for your help.
Ed
Old 25th April 2011, 06:49 PM   #2
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I don't think you would see any degradation with this design, assuming the lines are reasonably short and not crossing other noisy wires, like pairs carrying AC.
Old 27th April 2011, 08:57 AM   #3
Ian444 is offline Ian444  Australia
I got away with this to adapt 8-pin tubes to 9-pin sockets. The worry is the grid stopper resistors now are not close to the tube's grid pin. For these 6V6 tubes it worked out OK, but for other tubes it might not. You could attach the grid stopper resistor on the tube's grid pin and the other end to the PCB if there was any doubt, i.e. use the grid stopper resistor as an attaching wire. That's all I would be worried about, plus what Russell said, plus you might want grid stoppers on the screen grids.
Old 27th April 2011, 05:36 PM   #4
Thanks guys.
Ian, where'd you get the bullet plugs to jumper the tube socket to the circuit below?
Tube Sockets FaxMeBeer Tubes / Valves 5 7th February 2010 09:31 PM
question on old tube sockets jarthel Tubes / Valves 3 18th June 2007 10:32 PM
tube sockets bigpanda Tubes / Valves 1 15th June 2006 09:34 PM
Tube Sockets FrankRoss Tubes / Valves 4 19th March 2004 10:48 PM
Tube sockets with the same pin spacing as the tube Andypairo Tubes / Valves 5 15th March 2004 01:08 AM
Page generated in 0.07624 seconds (74.90% PHP - 25.10% MySQL) with 10 queries
