Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 13th April 2011, 08:17 PM   #1
amandarae's Avatar
Default Why Not KT-66?
Hello again guys!
If I can use 6550/5881 on my SSE amp, why not KT-66? B+ is 425 and Rk=560 ohms.
thanks
Abe
Old 14th April 2011, 01:28 AM   #2
tubelab.com's Avatar
why not KT-66?
I don't know.....why not? They worked fine in my amp. I used the Chinese version because I don't buy expensive tubes, and I thought that they were one of the better sounding 6L6GC types. Watch for red plating, you might need to increase the cathode resistor. I have a 750 ohm resistor in my board and collection of resistors on alligator clips for tweaking the cathode current. I don't know what I used with the KT66's it was 2 years ago. I have been using KT88's or EL34's only for the last year or so.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 14th April 2011, 06:23 AM   #3
amandarae's Avatar
Thank you George!
When I use 5Y3, I have VP=332, and Vk=26. At Rk=560, I am getting:
Pd=(332-26)*(26/560)= 14.2 watts.
According to KT-66 data when use as a triode, Max Plate is 400 and Power Diss(Pd) is 25 Watts.
I will try it. Thanks again!
Abe
Knight KB-85 stereo tube amp KT-66 ElectricMan Swap Meet 1 19th September 2010 04:17 AM
Kt-66 and Simple SE ixe13 Tubes / Valves 5 14th May 2009 01:24 AM
Another KT-88 cryo Tubes / Valves 23 1st October 2008 03:06 PM
Se Kt-66 MartinV56 Tubes / Valves 5 28th July 2008 01:50 AM
Need PP KT-88 amp design and KT-88 for triode use? Norris Wilson Tubes / Valves 7 23rd February 2005 12:12 PM
Page generated in 0.06669 seconds (71.21% PHP - 28.79% MySQL) with 10 queries
