SimpleSE Checkout/CL-90 Fail - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 9th March 2011, 02:34 AM   #11
wushuliu's Avatar
Originally Posted by rknize View Post
Is that an Antek toroid? Can you post the specs on it? It looks to me that you have wired the filament windings in series. This is not what you want. It sounds like your meter is a bit out of whack. 36V on the filaments is not good at all! It's best to check these before putting the tubes in.
Hi Russ youre right about the dmm, i put in a fresh battery. now reads 497v B+, 119v at primaries after adjusting voltage regulator back to previous setting.
antek specs attached
Old 9th March 2011, 02:43 AM   #12
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
OK, you want those 6.3 V windings in parallel. The datasheet shows different colors than the picture on the sheet (and your picture), but they tend to be a bit inconsistent. It *should* be blue-to-blue and green-to-green, but it is easy to figure it out. Just connect two of the same-color wires together and put your meter across the other two. If you measure double the voltage (~12.6), you are putting them in series and not in parallel. If you measure almost nothing, then you already have them in parallel and you can connect the two loose wires together.
Old 9th March 2011, 03:32 AM   #13
The sticker on the side has been accurate for me every time as far as diagrams/colors go.
Old 9th March 2011, 03:49 AM   #14
wushuliu's Avatar
That did it! thanks so much Russ. Only tested one channel, but there was music! B+ at 445v with 6l6s...
90+90 volt rails east electronics Solid State 42 5th April 2011 01:38 PM
Use CL-90 to slow 5Y3? Troncones Tubes / Valves 7 2nd March 2011 02:35 PM
Checkout for Simple Se royd55 Tubelab 1 3rd January 2010 07:09 PM
F/S Gold Lion KT77/EL34 12AT7 5AR4 SimpleSE tubes $90 nvrgdenuf Swap Meet 0 7th September 2009 07:48 PM
Need Amp For 90-0-90 V DC Drafance007 Solid State 15 12th October 2003 08:03 PM
Copyright 1999-2017 diyAudio
