| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
Hi All,
I am rebuilding my Simple SE amp and I have a PWR XFMER question. I am using the Edcor PWR035 XFMR and thought I had taken enough pictures of how I wired it before taking it apart but apperentlly not From the Edcor schematics, it looks like the black and black/white wires are for the 115V power input and return. The two green cables I am not sure of. They do not show up on the schematic and they do not seem to be ground cables? If I ohm them to the chassis ground, it is an open circuit. Should these green wires be grounded?Thanks! |
#2 |
Electrostatic shield? Are all of the other wires in the diagram accounted for?
#3 |
No they are not. From the diagram, the ceter tap wire for the 370V and the 6.3V I have taped up since they are not used, these are shown in the diagram.
Besides the two green wires there are also a pair of grey wires that are not shown in the diagram. I have also taped these up since I do not know where they go? |
#4 | |
I'd contact Edcor directly. I e-mailed them yesterday morning with a question on custom OPT winding, and got a reply back within about 10 minutes.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#5 |
What I meant was, are there any wires shown in the diagram that are physically missing?
#6 |
Guys,
Thanks for the replies, sorry for my late reply. After checking my purchase order, I realized that I actually ordered the 059 and not the 035. I did ask about the 50V gray wires as to what they would power but did not get a response back. Thanks again! |
#7 |
That is a 50V@50mA winding that would typically be used for a negative bias supply. Often these are taps off of the main high voltage secondary, but here they have made it a separate winding (which is nice). You don't need it at all for the SSE.
| Power XFMR Choice | sherpa | Tubelab | 3 | 18th October 2010 09:05 AM |
| MC Step-up Xfmr and SNR | analog_guy | Analogue Source | 13 | 13th January 2010 04:30 AM |
| Anyone have SPICE models for PSU Toroidal Xfmr ?? | 13DoW | Power Supplies | 49 | 2nd April 2007 04:01 PM |
| rectification and xfmr stress | beamnet | Tubes / Valves | 16 | 19th September 2005 03:51 PM |
| Page generated in 0.08812 seconds (75.67% PHP - 24.33% MySQL) with 11 queries |
