Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 27th February 2011, 06:01 PM   #1
boywonder's Avatar
Default Reducing filament hum in a Tubelab SE
I posted this question in an existing/old thread over in the tubes forum, but it appears that I'll get more action over here.............
When playing the Tubelab SE on my Half-Changs (95db), I have a little hum that I would like to reduce. It's not bad at all, but if I could knock it down a bit that would be great.
So.......I'm running 300B's, and an Edcor XPWR-131 power transformer.
C1, C3 and the other stuff around the filament regulator is per the schematic. I'm measuring 1.25V PP at C1, and about 28mv PP at C3, and 5.93V dc at C1 Are these reasonable values?
Per Georges calcs from another related thread, it appears that I have less than .5V of headroom for the regulator. I'm measuring 4.9V at the filament tube socket.
5.93-1.25/2=5.3v.
I've paralleled 34000 uf with C1, lowering the Vpp to about 540mv. This, at least on paper, is enough headroom for the regulator, but the ripple at C3 is still about 30mv PP with 15000+34000 uf capacitance at C1.
I've also experimented with a separate (6A current rating) filament transformer that increases the dc volts at C1 to about 6.3V, which should be plenty of headroom for the regulator. This had no effect on the 28-30mv ripple at C3. Adding another 10000 uf to C3 also had very little effect on the ripple at C3...
Any ideas?
Old 27th February 2011, 10:27 PM   #2
Have you measured AC at the speaker terminal? My TSE is 1 mV and no audible hum from my 97db speaker. I use choke in place of R4.
Old 27th February 2011, 10:54 PM   #3
boywonder's Avatar
I'm using a 5H choke in place of R4 and I have 15mv PP at the speakers.
Old 28th February 2011, 01:47 AM   #4
gootee is offline gootee  United States
Do you have some photos that show your layout and wiring? Maybe you left some "loop area" in some wire pairs (instead of twisting or shielding them), which might be radiating and/or picking up AC like antennas. Or maybe an input ground reference point shares some portion of a ground return conductor with some AC.
Old 1st March 2011, 03:12 AM   #5
boywonder's Avatar
Here it is. Power transformer is on a separate chassis with an umbilical. RCA signal cables are small coax........I suppose that I could twist the heater wires where they enter the chassis over to the PCB.
Old 1st March 2011, 03:49 PM   #6
That's very high. Something doesn't seem right.
1. Are you using volume pot at the input and how far is it turned up (or down)?
2. What value are you using for R31 and 32? This changed the hum level for mine. Tubelab said something about oscillation when lower value was used.
Old 1st March 2011, 06:15 PM   #7
boywonder's Avatar
No volume pot, power amp only.
I'm using 36K R's for R14 & R25 (Mosfet sources) since my B+ is 350-400 per George's notes.
Old 1st March 2011, 06:33 PM   #8
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Have you tried shorting the inputs to ground?
Old 1st March 2011, 06:42 PM   #9
boywonder's Avatar
The 15ma is with the inputs shorted to ground. Doesn't change much with my preamp plugged in either.
15ma PP/(2xsqrt2)=5.3 ma RMS
Old 1st March 2011, 06:58 PM   #10
rknize's Avatar
Do you have 100x probes so that you can look at C5 and C7?
Tubelab SE with 2A3 Hum Doc Jr 8156 Tubes / Valves 22 26th February 2011 08:34 PM
Filament switching off in Tubelab SE Nikon1975 Tubelab 1 23rd February 2010 04:01 PM
Hum Troubleshooting on My Tubelab SE with 2A3 Doc Jr 8156 Tubes / Valves 2 13th August 2009 04:32 AM
Novel method to reduce filament hum in SE Amp? dshortt9 Tubes / Valves 9 26th April 2009 06:37 PM
Tubelab SE input tube filament Evenharmonics Tubes / Valves 3 25th January 2009 12:10 AM
Page generated in 0.10978 seconds (79.94% PHP - 20.06% MySQL) with 11 queries
