Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 3rd August 2011, 11:51 AM   #11
Ian444 is offline Ian444  Australia
To the OP tbobbyt, I would get the 8 ohm output trannies, and run your 4 ohm speakers at first for the short term, just don't crank it up too hard, and keep an eye on the tubes if you do. More than likely it will be fine for the short term, and sound decent too. I understand you eventually want to get some 8 ohm speakers, if this is the case, don't stress, the amp can run 4 ohm speakers in the meantime.
4/8 ohm speakers on single tap OPTHide this!Advertise here!
screen tap on OPT hirafu_boarder Tubes / Valves 1 29th September 2010 10:26 AM
Mysterious OPT winding tap Klimon Tubes / Valves 8 15th May 2009 10:06 AM
Would you use a 4 ohm tap with these speakers? Saurav Tubes / Valves 5 26th March 2009 02:42 PM
What's the closest I can get to a 4 ohm load using 3 single coil, 6 ohm drivers? The Paulinator Multi-Way 9 11th May 2004 07:04 PM
