Simple SE choke - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 4th July 2012, 03:19 AM   #11
zman01 is offline zman01  Bangladesh
Default Working voltage vs VDC
Using Google I came across a couple of links where it says that insulation test voltage is 2 x working voltage + 1000 volts - one of these from diyAudio:
Post #7 on this diyAudio thread: 813 amp and old choke
I am not sure if this is case for all chokes. A couple of other documents indiciated that VDC should be 1.4 times VRMS. Again, the Edcor choke on my shortlist is rated for working voltage of 1000 VRMS according to an e-mail from Edcor.
The Edcor power transformer I have in mind is this one: EDCOR - XPWR002-240, which is 720V rated (360-0-360).
Old 5th July 2012, 04:19 PM   #12
I asked Transcendar this very question about the TT-010-CH. Here is their response:
"Hello,
I don't normally rate inductors for a voltage.
They are rated for current and inductance.
However, I do test the insulation of each inductor to withstand 3000 volts DC.
Thanks,
Gery"
I purchased this unit, and have it in place on my 300B Tubelab SE.
Old 5th July 2012, 05:28 PM   #13
Good info acceler8, thank you.
I have asked Edcor the same question.
Does Transcendar make power transformers?
Old 10th July 2012, 10:52 PM   #14
Default Edcor reply on choke
Edcor has got back - the transformer has a maximum DC current rating of 200mA and the insulation testing is 1000 volts DC to frame or end bell.
1000 VDC is lower than the Transcendar unit, but should be ok I guess, as lot of Hammond chokes being used are rated for less.
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 02:16 AM
Simple SE Simple Power Drive? Skorpio Tubelab 1 5th May 2011 09:45 AM
Tubelabs SE vs. Simple SE ?? albireo13 Tubelab 16 21st February 2010 09:00 PM
Simple Simple SE questions nodiak Tubelab 57 2nd February 2010 11:02 PM
Triad C-14X choke (Simple SE) Ty_Bower Tubelab 3 15th July 2008 05:36 PM
Copyright 1999-2017 diyAudio
