| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
I am beginning to gather the parts for my Tubelab SE build. For the PS bypass cap I am considering either a Sprague motor run oil cap(370v 100uF) or a Solen cap(400v 100uF). They are about the same price($28) when s&h is considered.
Anyone compared these? Other options at this price point? |
#2 |
I would go with 400V if using 300B tubes.
#3 |
Thanks for the reply. I should have mentioned that I will be using 300B's.
#4 |
The motor run is probably 370v AC which means quite a bit higher rating for DC. Motor runs are normally preferred over the solens as they are oil filled and might have a lower ESR than the solen. Not sure. OH, and they just look cooler
#5 |
The motor run caps are 370vac and 650vdc.
#6 |
I would use whichever fits/looks the best, if the price is about the same. I don't know which would have the lowest ESR, as it depends on the construction of the cap. The difference is probably not significant.
#7 |
Very interesting question, it made me think about these Obbligato film oil caps. I wonder if I can use them as supplemental power supply cap with my Simple SE.
Unlike the solen's these are oil filled. I read somewhere these have low induction; I don't know what that means but thought I should write it here. Obbligato Film Oil 70uF 630V | Diy HiFi Supply How different are these technically from motor run caps? Motor run caps will sound better than these obbligato's no matter what? |
#8 |
tarmac ripper
I have been using in my PSUs sturdy and reliable and cheap and indeed very good ASC capacitors since ages. No coming back. Bulky but worth every penny.
#9 |
IMHO (and all cap comparison test that I have read) the best sounding motor run power supply caps are ASC, which actually use oil, most of the other motor run caps use a gel. It would be interesting to know if this is what makes the ASC a better sounding cap over the Dayton and other gel motor run caps.
Lee Hankins |
| Motor run caps? | albireo13 | Tubelab | 12 | 5th March 2010 08:35 AM |
| motor run caps | grahamb | Tubes / Valves | 3 | 17th September 2009 11:14 PM |
| motor run capacitor | milen007 | Parts | 12 | 28th June 2008 05:49 PM |
| Motor Run Capacitor | Zap | Tubes / Valves | 2 | 14th May 2008 09:59 PM |
| dual value motor run caps | wicked1 | Tubes / Valves | 4 | 6th February 2008 09:37 PM |
| Page generated in 0.08261 seconds (82.73% PHP - 17.27% MySQL) with 10 queries |
