#41 |
Are the 500V Cornell Dubilier 380LX any good for the Simple SE? They are 85C so wondering if they are reliable?
#42 |
Are the 500V Cornell Dubilier 380LX any good for the Simple SE?I bought some and stuffed them in an SSE board. They seem to work OK but I haven't used the amp enough to judge reliability. I would guess that they will be OK if you mount the caps on the back of the board to avoid radiant heat from the output tubes.
Newark (Farnell) now has some 105C rated Nichicons. I just got 10 of them but haven't tested them yet.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#43 |
Also, the area around the rectifier runs a little hotter on the TSE than the SSE, due to some additional power resistors (particularly R6).
#44 | |
Any thoughts on this? |
#45 |
If I had to re-phrase the question today....
If the mosfet drain-source voltage rating is 500V, what prevents that spec from being exceeded (especially at startup) in the circuit? It seems that with 300B's the source voltage is as negative as -300 volts or more, not considering the + voltage on the drain. Still wondering myself......... |
#46 |
The MOSFET will never see that. The gate is derived from B-. So as B- comes up, gate voltage is applied, current flows through R14 causing a drop there that is proportional.
#47 |
Found this device:
FQH8N100C Fairchild Semiconductor MOSFET It's a 1000V, N-channel with a Crss of essentially zero above a Vds of 10V. Seems ideal? |
| Thread Tools | Search this Thread |
| Tubelab SE vs Simple SE | Pez | Tubelab | 25 | 29th October 2011 02:16 AM |
| Tubelab SE buzzing | Evenharmonics | Tubelab | 19 | 15th October 2010 03:23 PM |
| Need Help with Tubelab SE | lth1 | Tubelab | 9 | 1st October 2010 09:06 PM |
| tubelab se | DimZ | Tubelab | 58 | 20th January 2009 12:47 PM |
| Tubelab SE finished but need help. | Evenharmonics | Tubes / Valves | 50 | 8th July 2008 06:04 PM |
| Page generated in 0.09337 seconds (79.20% PHP - 20.80% MySQL) with 11 queries |
