Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 21st December 2010, 07:50 PM   #21
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
You'll also need to tweak the source load resistor as well. George mentioned that this was one of the changes he would like to make to this PCB: allow for separate supply rails for the FETs so that they don't have to stretch all the way from B+ to B-. You wouldn't even need a B- on the PCB anymore if you supplied your own +/- 100V rails.
Obviously you can do with with a bit of trace cutting.
Old 23rd December 2010, 02:14 AM   #22
boywonder is offline boywonder  United States
boywonder's Avatar
Default an update......
The amp is up and running. I'm running it on my main system with a variac at about 90% of full throttle until the Edcor XPW131 shows up.
I've been chasing a problem of one channel not working since yesterday....long story short, the vintage 4 pin ceramic socket wasn't making good contact with the tube pins, so I unsoldered the socket, extracted the contacts, re-tensioned them, and re-installed. Problem solved, at least until the contact tension Peters out again.
I ended up removing R5, R6, C6, C7 from the board and putting them on a perf board daughter board mounted to the side of the chassis. This solved two problems; the caps on the board were too tall for my chassis (they touched the bottom cover), and this change allowed me to use big honkin' Panasonic TS-ED and TS-HB snap ins. I also changed R5 to 3K 6 watt and C7 to a 180uf Panasonic TS-HB snap in. With the Hammond 273BX (350-0-350) the B- is around 230V.
I'm still trying to get the hang of this MOSFET thing; I'm assuming that the total voltage across the MOSFET (B+ to B-) needs to be at least as much as the driver tube voltage swing plus some margin, is this correct?
A few tweaks remain. The square waves are quite square, with a little wiggle/underdamped response at the top of the wave. I'm going to swap the metal films in the amp for CC, and/or use a higher value R.
Old 19th June 2011, 01:02 AM   #23
Doug Kim is offline Doug Kim  South Korea
Doug Kim's Avatar
Which volume pot have you all used? Is there one that can directly be soldered on the board?
Doug
Old 19th June 2011, 03:32 AM   #24
Evenharmonics is offline Evenharmonics  United States
Doug
I use Alps 100K Ohm.
Old 24th June 2011, 10:19 PM   #25
Doug Kim's Avatar
I purchased an Alps 100k Ohm which looks just like the one in the pic (blue velvet), but it does not fit to the Tubelab SE board. I must have checked the spacing between the pins before ordering, and I can use the pot for my Aikido project anyway so nothing hurts.
Anyways, which pot fits to the board without modification?
Doug
Old 24th June 2011, 11:33 PM   #26
Sorry, I didn't realize the pin spacing is different. I have it mounted on chassis and wired it to the board. Is it possible to bend the pins little to fit the board?
Wiring the Tubelab SE without a volume potHide this!Advertise here!
Wiring the transformer to the Tubelab SE blue lander Tubelab 33 17th March 2010 05:09 PM
Volume pot for Simple SE bigjppop Tubelab 4 17th January 2010 08:50 PM
Volume pot for simple se newtube Tubelab 7 19th May 2009 04:34 AM
Yet another volume pot wiring question MikeHunt79 Everything Else 7 14th November 2008 06:26 PM
Pickup Wiring, do I need a volume pot? mpm32 Instruments and Amps 4 17th May 2005 04:01 PM
Copyright ©1999-2017 diyAudio
