Wiring the Tubelab SE without a volume pot Wiring the Tubelab SE without a volume pot - Page 2 - diyAudio
Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 16th December 2010, 03:00 AM   #11
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Sounds like an adjustable NLD would be the perfect candidate.
Old 16th December 2010, 02:49 PM   #12
boywonder is offline boywonder  United States
boywonder's Avatar
Thanks! I'll bump up R10 & R21 a bit. Pretty obvious now that you mention it.......
Old 21st December 2010, 12:59 AM   #13
boywonder's Avatar
Well, I bumped up R10 & R21 a little, and that fixed the problem of running out of pot adjustment on the 5842's.
The amp is presently functioning, although my B- is around -300V. I smoked R5 once already, so I replaced it and swapped out the MOSFETS, replacing the 2SK3563 with the 900V rated parts (2SK3564 IIRC).
I replaced R5 with a 3K R in an attempt to reduce the B- voltage, but then I ran out of pot adjustment on the 300B's......so I put a 270R back in for R5.
My transformer is a Hammond 273BX 350-0-350 and runs a bit high. I've added another RC stage in the PS; instead of just a choke in place of R4 I put the choke, then another RC stage. My B+ is about 400V with a 5AR4 when running about 65ma through the 300B's. But the excessive B+ is making the B- very -ve.
I've been calculating the various expected voltages down the bias circuit to ground, but I don't really know how much current is flowing through the MOSFETs to determine whats good and whats bad.
I just placed an order with Edcor today for a XPWR131, so the project goes on hold...
so....a few questions.....
What are the symptoms of blown MOSFETs?
Whats a reasonable B- voltage with the Edcor 330-0-330 transformer? -300V seems like a long way from -150V....I'm assuming the -150 is with a transformer suitable for 45 outputs.
Old 21st December 2010, 03:38 AM   #14
rknize's Avatar
I dusted off my TSE (still on the breadboard) to check. I have the XPWR131 in there, obviously, and with it set in 300B mode I see about -270V of B-. This is with no tubes, so it will sag as the B+ rail loads the transformer.
Old 21st December 2010, 04:08 AM   #15
Evenharmonics is offline Evenharmonics  United States
My TSE has -275VDC for B- under load and around -290 without load.
Old 21st December 2010, 01:02 PM   #16
Nikon1975 is offline Nikon1975  Austria
Speaking about pots. Is 50k the max pot value the 5842 can support ? I have 100k on my TSE 45, is it worth to replace it ?
Thanks,
Davide
Old 21st December 2010, 02:04 PM   #17
rknize's Avatar
Oh, I just realized that the -150V number was coming off the schematic. Yeah, that would be for 45s...the original application of this design. What are you using for R14/R25? The values on the schematic are too low for the 300B setup because of the higher B+ and lower B-. The FETs have to deal with too much dissipation.
Old 21st December 2010, 03:54 PM   #18
This quote is from tubelab website. "R14 and R25 should be 36 K on boards that operate at 350 to 400 volts" Link
Old 21st December 2010, 04:10 PM   #19
rknize's Avatar
I just wanted to make sure you noticed that as it is not part of the instructions.
Old 21st December 2010, 06:24 PM   #20
boywonder's Avatar
I'm using 36K.
I've been contemplating a small separate transformer to power the bias circuit, say a 120:240 tiny thing as an experiment......One problem is that my power transformer is on a separate chassis and my umbilical does not have enough wires to bring the mains voltage into the amp chassis.
I would then play with the various bias circuit R values to get the bias pots back in their happy place. Perhaps another RC stage for the bias as well. I suppose that adding more RC sections even off of the power transformer secondary would be interesting; burn some voltage and get more filtering.
Wiring the Tubelab SE without a volume potHide this!Advertise here!
Wiring the transformer to the Tubelab SE blue lander Tubelab 33 17th March 2010 04:09 PM
Volume pot for Simple SE bigjppop Tubelab 4 17th January 2010 07:50 PM
Volume pot for simple se newtube Tubelab 7 19th May 2009 03:34 AM
Yet another volume pot wiring question MikeHunt79 Everything Else 7 14th November 2008 05:26 PM
Pickup Wiring, do I need a volume pot? mpm32 Instruments and Amps 4 17th May 2005 03:01 PM
Copyright ©1999-2017 diyAudio
