#21 |
I took a few voltage measurements with the 6П14ПEВ (EL84M) in my Simple SE. The socket adapters make for very easy voltage checks, since the legs of the 9 pin sockets are slightly exposed above the chassis. I have a two part cathode resistor - 250 ohms in series with another 510 ohms. Tonight I jumpered out the 510, leaving only the 250 ohms.
B+ is 329 VDC. Cathode voltage is 10.9 V on one channel, and 10.8 V on the other. This works out to 13.9 watts total dissipation in the tube, which might be a little higher than I'd like. Oh well. I think it does sound better than it did the previous night, before I jumpered the cathode resistors. Thank you for the kind words, Neon. I started out building wooden stuff with framing lumber, a circular saw, and deck screws. It looked like hell. Just keep building stuff. Take care in your work, but never worry about how it will turn out. Consider every project a learning experience to help you practice new techniques. Kinda like building amps. I think I still have a lot of room for improvement, but I'm still happy with what I can do today. Anything you build yourself will (almost) always sound better. |
#22 |
Yes, too hot. Before I shut it off last night I peeked in through the plates holes. Some small sections of one of the grids was glowing slightly. Guess I need to go with a larger cathode resistor.
#23 | |
I have another set in another Simple P-P with the screens at 320 volts and the plates at 430 volts! I get 30 watts out of a pair and still there is no glow!
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#24 | |
I eased back on the cathode resistors and jumpered for 510 ohms. Cathode voltage is 13.8 volts, which gives a nice and easy 8.5 watts total dissipation. I think it might sound better than it did last night, too. I'd better be careful, or I might get used to these little tubes in my Simple SE. |
| Thread Tools | Search this Thread |
| FS LSK389 + standard 8 pin DIP adapter | merlin el mago | Swap Meet | 0 | 14th October 2010 08:18 AM |
| Potentiometer with bass boost pin for Simple SE? | dubdub | Tubes / Valves | 4 | 27th October 2008 03:57 AM |
| Pin polarity for T-amp AC adapter? | Raoul | Class D | 4 | 24th August 2005 03:32 AM |
| 28 pin SSOP to DIP adapter | seangoesbonk | Parts | 8 | 16th September 2004 07:50 PM |
| XLR 4pin to 3 pin male adapter | kevinhero | Parts | 3 | 18th November 2003 01:09 PM |
| Page generated in 0.09105 seconds (72.28% PHP - 27.72% MySQL) with 11 queries |
