Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 19th November 2010, 05:28 PM   #1
boywonder is offline boywonder  United States
boywonder's Avatar
Default TubelabSE Are my heatsinks big enough for 300B's?
Are my heat sinks big enough for 300B's?
Everything except the tube sockets is bottom mounted.....
Old 19th November 2010, 08:39 PM   #2
boywonder's Avatar
One other question.....after debugging I'm planning on running a mullard CV378/GZ37 rectifier. Any issues? is a 47uf first cap OK with this rectifier? I cannot locate a datasheet.
PSUDII shows about 20V additional voltage drop compared to a 5AR4.
Old 19th November 2010, 09:27 PM   #3
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
The one on the regulator/rectifier needs to be quite a bit larger.
Old 20th November 2010, 07:13 AM   #4
lth1 is offline lth1  United States
My Tubelab SE Edcor 250V CT PT has a no load voltage of 268V.
With 5AR4 as rectifier, first cap is ASC 2.58uf, then CX14 choke(6H 154ohms), and second cap is 98.5uf ASC, B+ is 278VDC @ 28mA.
With GZ37 as rectifier, first cap is 3.3uf, CX14 choke, and 98.5 ASA cap, B+ is 277VDC @ 27mA.
Hope that this will help with installing the GZ37. I do like the sound of the GZ37 better than the GZ34, at least with my test setup
Lee Hankins
Old 20th November 2010, 02:55 PM   #5
Evenharmonics is offline Evenharmonics  United States
Maybe just little bit. Mine (300B TSE) is not much bigger than what's pictured and it works.
Old 20th November 2010, 02:58 PM   #6
Are the heatsinks for Q1 & 2 and U2 & 3 mounted to the board or are they hung off of semiconductor leads?
Old 20th November 2010, 04:46 PM   #7
boywonder's Avatar
Well, I suppose I'll try them out.....the regulator has thermal protection, correct?
I have other PC CPU heatsink organ donors, so if I can shoehorn in something bigger I'll do it.
They are hung off of the semiconductor leads.
TubelabSE Are my heatsinks big enough for 300B's?Hide this!Advertise here!
Big Heatsinks for sale lgreen Swap Meet 3 20th January 2010 09:42 PM
Big HeatSinks for sale gengis Swap Meet 13 24th January 2008 05:13 PM
are my aleph 2 heatsinks big enough ? dhole Pass Labs 12 8th December 2004 10:25 PM
BIG heatsinks source!! Mattyo5 Swap Meet 10 22nd May 2003 04:28 PM
where to find big heatsinks? wake rider Solid State 3 14th January 2002 04:38 PM
Copyright ©1999-2017 diyAudio
