Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 14th November 2010, 02:24 AM   #11
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Next to digest is PowerDrive.
PowerDrive simplified:
Part 1:
The CCS provides the driver triode with the ideal load. This lowers its distortion. Use a resistor load if the driver is a pentode.
Part 2:
The mosfet seperates the output tube from that troublesome coupling cap. The mosfet has a very high input impedance. The impedance is mostly the resistor connecting to the bias pot. Adjust the resistor value to make the driver happy. The driver and the coupling cap now see a constant impedance regardless of signal level. They are happy.
The mosfet feeds the grid of the tube with a very low impedance drive voltage. It can source the grid of the output tube with all of the current it can eat if driven hard, and it can deal with Mr. Miller in triode mode.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 14th November 2010, 08:09 PM   #12
DualTriode is offline DualTriode  United States
Hello tubelab and All,
I sat down with your printed posts and PowerDrive from your web site. I made some observations that were interesting to me. TubelabSE has grid bias and Simple SE has cathode bias.
A SET with cathode bias can also have itsí own version of bias drift. If the output goes into cutout the cathode voltage falls towards earth. I can imagine non-musical shoot and overshoot during the readjustment of the equilibrium of the interstage coupling and cathode bias capacitors. None of this shows up on theoretical load lines or in the ideal world of spice.
Thanks for tickling my brain George.
DT
All just for Fun!
Old 14th November 2010, 11:45 PM   #13
So can a cathode biased P-P amp. The cathode bypass cap can be made excessively large which will effectively remove bias shift due to cathode voltage change though.
I have seen small changes in the cathode voltage in the Simple P-P when driven to extreme overload.
Another "bias" issue is unregulated screen grid voltages in pentode amps. The screen current can vary a bunch in some tubes as the drive is increased. If the usual resistor - capacitor screen supply is used, another time constant is created along with the overload and recovery issues.
Any and all of these describe possible modes for overload and recovery issues. More than one of these can be at work in any given amp.
Old 7th January 2018, 03:36 PM   #14
michaeljessen is offline michaeljessen  Denmark
HI
Will it be ok with a cathode bypass cap C-8 & C-10 in the Tubelab SE 4700mf 16V in sted of 6,3v ? I can get a Audio note kaisei 4700mf 16V for free The specification in the part list for the SE list 4700mf 6,3V for C-8 & C-10. Can i use a 16v insted of a 6,3v ?
Michael
Old 7th January 2018, 05:34 PM   #15
16 volt parts are fine if they will physically fit in the board.
Tubelab SE Coupling CapacitorsHide this!Advertise here!
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 02:16 AM
On going saga with Tubelab SE lth1 Tubelab 15 26th October 2010 06:02 PM
Need Help with Tubelab SE lth1 Tubelab 9 1st October 2010 09:06 PM
tubelab se DimZ Tubelab 58 20th January 2009 12:47 PM
Tubelab SE monoblock? Evenharmonics Tubelab 8 28th April 2008 07:02 PM
