Simple PP vs. Tubelab SE - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 13th November 2010, 02:03 AM   #21
Tubelab_com's Avatar
George: I think you mean FE126?
Probably. I'm not good with numbers, so I became an engineer. Go figure.
Didn't go to college until I was nearly 40 years old. My company paid me to get a degree.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 2nd January 2011, 02:20 PM   #22
Originally Posted by Allen Wright View Post
This is flat out INCORRECT. P-P cancels even order harmonics generated WITHIN the amp - it DOES NOT affect the music's harmonics, second or otherwise.
Originally Posted by tubelab.com View Post
A good SE amp will have the second harmonic as its primary THD component.
A good P-P amp will add some second harmonic, and the primary THD component will be a mix of third and some second harmonic. Some higher order harmonics will be added on strong signals.
A well balanced fully differential P-P amp will add nearly no second harmonic and its primary THD component is third harmonic.
I did some measurements of Tubelab SE (SET) and push pull amp Dynaco ST-70 (restored original PC board w/ updated power supply) with my cheap tools (not lab grade) and noticed some differences when fed the same signal. What does this mean about Dynaco ST-70?
I also measured Parasound HCA-750A (P-P transistor amp) and noticed the diminished even order harmonics and prominent 3rd, 5th, 7th and 9th order harmonics. So I'm wondering, is this common with push pull amps?
Old 2nd January 2011, 03:34 PM   #23
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Yes, an SE amp will have a dominant 2nd order harmonic while a PP will typically (though not necessarily) have a dominant 3rd, 5th, etc. The feedback loop on the ST70 helps clean up the rest of the harmonics. The TSE has no feedback at all. Do you have a spectra of the source you are using?
Old 2nd January 2011, 03:48 PM   #24
But I noticed almost same level of 3rd harmonics from both and yet there is a significant reduction of 2nd harmonics from P-P circuit.
The source I used was 1KHz sine wave that was part of ARTA program I downloaded.
Old 12th September 2015, 09:13 PM   #25
One question : What sounds better The Tubelab or the Dynaco ? Please PM if you'd be so kind !
Old 13th September 2015, 02:37 PM   #26
Sorry, I haven't done a proper side by side comparison of the two and I sold Dynaco a few years ago.
Tubelab Simple SE questions Skorpio Tubelab 20 2nd November 2013 04:39 PM
Electrolyticless Tubelab Simple SE nic6paul Tubelab 26 20th August 2013 12:56 PM
Simple SE Tubelab.com Fenn Tubelab 36 14th October 2010 01:42 PM
7027A with tubelab simple se pforeman Tubelab 10 8th November 2009 02:48 PM
Tubelab Simple SE v.2 nic6paul Tubelab 3 1st November 2009 12:59 PM
Copyright 1999-2017 diyAudio
