Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubelab Discussion and support of Tubelab products, prototypes and experiments |
#71 | |
Ian - that's almost too funny: I had a nice listening session this afternoon with Jeff ( VinylKid), during which we rolled a few nice numbers from a stash he brought along. Just tubes, friends, just tubes - the days were I could safely play with swapping tubes while "participating" are long past ![]() NOS Mullard CV4024 vs GE JAN 6201 - waddya think? Amperex (Holland) EL84 vs 6P14P-EV - same question ![]() put the 2 together .... ![]() But regarding the question of fixed vs cathode bias - that's were the fun starts. I'm in the middle of another project that is having a birthday coming up soon - rebuild of Jolida 302 ( EL34 P/P). The stock pre-map/ phase splitter stage has been replaced with Gregg van der Sluys' very cool Dynamutt board. Originally intended as (yet another ![]() Anyway, part of the process "reconfiguring" the original stock Jolida chassis and boards (although my first tube amp, it's certainly not a "treasured classic", and certainly one on which I have no aversion to performing major re-constructive surgery) is the gutting of a large PCB that houses the pre-amp/phase inverter and output stage bias network, including trim pots. It's been a rather creative bit of work to house Gregg's new board (designed to be a direct physical drop-in replacement for the original Dyna ST70 board), as well as retain that portion of the Jolida board with the PCB mounted bias trim pots. At this stage of the game, I'm thinking it likely would have been easier to spend the extra bucks on closely matched output tubes (the original stock Sveltana's are coming on 10yrs old) and reconfigure for cathode bias, which has been the case with all my other amp builds, kit or DIY. The Simple P/P was my first P/P kit - tons of fun, and well designed with lots of latitude for experimentation that I have yet to fully explore - but for something as major a departure from George's "classic" design as you're contemplating, I'd be inclined to simply PtP the whole thing. * Classic Valve Design - Dynaco Clone and Original Design Boards and Repair Kits - Dynaco ST-70 Modifications Did I say already how much fun I've had over this project? If I was previously close to ennui, that's gone (for now) cheers, all
kinda burnt out - taking a break |
#72 |
There is a thread in diytube.com in Stereo 35 form called " Improved SCA--35/ST-35 Performance " with link to this article:
http://www.tronola.com/A_New_Look_At...riend_Rev0.pdf I think this is what George was talking about earlier instead of the LED's. Looks inexpensive to try should help OT tubes last along with possible sonic improvements. I've got to try it. Randy Last edited by rmyauck; 29th November 2010 at 06:48 AM. |
#73 |
Dave also mentions in another thread on diytube that one should purchase Output Transformers with a 25% UL ratio for EL84/6V6 PP amps or performance will suffer. There are a lot of 40% out there which is perfect for 6550 tubes. EL34 like 34% and KT-88 20-50%.
#74 | |
Thank you for that link. While much of the theory presented is beyond my current level of understanding, I think I get the general concept. If you or anyone else is going to adapt this mod to their SP-P,I would appreciate a drawing detailing the connections to the SP-P board. I don't want to screw up the nice little amplifier I built.
"We provide the music, you provide the silence." - Charles Mingus |
#75 |
Randy - thanks for the very interesting link.
Note the author's cautions about application of this method to designs other than the SCA/ST35. Of course if you built a Simple P/P with Dynaclone OPTs you'd probably be fine.
kinda burnt out - taking a break Last edited by chrisb; 29th November 2010 at 04:57 PM. |
#76 | |||
![]() jeff |
#77 |
Thanks! I thought you guys would be interested too! In the thread Dave mentions you could use it with other output transformers, as long as they are 8K primary. He mentions the Heathkit 10K primary wouldn't work so well as many people build clones. The Simple PP is a much the same design of Cathodyne Splitter or Concertina and cathode bias on output tubes. Most of the vintage small PP amps used this exact design with different input tubes depending on designers. I can't see why it wouldn't work on LTP or Differential splitter amps too. George already has the necessary 1K and 100 ohm resistors added in his design which is safer for the tubes. George does have a resistor/ cap for each output tube cathode bias which is the best method of that design to work it's best also.
Dave also mentions fixed bias is possible just like some big tube amps use by adding a bias PS, but that is more complicated and money, but if you don't want any SS that is another way. I like the idea of being able to set the bias for each tube if more pots are added as I have a number of unmatched 10BQ5's I got for very low $. I can't see why it wouldn't work with the 8K primary Edcors and others. I thought I read somewhere the 8K Edcors with UL taps have the ideal 25% ratio. Of course it takes a bit of the "Simple" out. He is also developing a design for the larger amps that don't have fixed bias. Regards, Randy |
#78 |
"special" ![]() the original purchase date was invoice for the Jolida was 2000, so I might have mis-remembered if I bought the Svetlana's separately - but certainly they're at least 9yrs old While I will admit that some of the cheaper tubes of Chinese origin that I've heard were "sure guano", by all accounts the latest Black Treasure series by Shuguang are not to be sniffed at - for $170/pr for 6CA7, I certainly hope not.
kinda burnt out - taking a break Last edited by chrisb; 29th November 2010 at 07:32 PM. |
#79 | |
http://www.diyaudio.com/forums/tubes...amplifier.html It should be noted that the Dynaco ran all 4 output tubes on a single common cathode resistor. This is an obvious cost saving move in more ways than one. When an amp is driven hard the tube current goes up. This strains the power transformer. By using a common cathode resistor the cathode voltage will creep up slowly (due to the common bypass cap) when the amp is driven to full power continuously, reducing the total power supply current so a smaller power transformer can be used. This is why the measured distortion goes up and the power output goes down on the test bench when both channels are driven. This is not usually an issue with music since the average power output is far below full power. The Simple P-P uses a seperate cathode resistor for each channel with a rather large bypass cap for each. The bias should not change at all with music applied even well into clipping. It may change a few tenths of a volt under continuous sine wave clipping. Fixed bias or its equivalent can become advantageous if more power is desired. I have succesfully extracted 30 WPC from a Simple P-P board by using a combination of quasi fixed LED bias and regulated screen voltage. The Simple part goes out the window though. One thing not made clear in the Dynaco mod article is the need for having the cathode bias track the supply voltage. It is OK for the "fixed cathode bias" to track the total B+ as shown in that article. This is advantageous in UL or triode mode. The usual rule of thumb is that the grid (or cathode) bias must track the SCREEN grid voltage in a pentode mode amp. In extreme power experiments with the Simple P-P it has been determined that you want the cathode voltage fixed and the screen voltage fixed. Let the total B+ vary with the line voltage, it will only affect the maximum power output slightly. I think most people get far too serious over just what the exact ratio for UL is supposed to be. It might make a little difference in full power measurements into load resistors, but real speakers are nowhere near a constant resistive load so the plate load impedance will never be exactly 8K so theory goes out the window. My thought is, if you have a transformer, try it. I am using 6600 ohm OPT's in my P-P amp because I have a bunch of them. I have a pair of 8K OPT's too, but I think the 6600's sound better.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before...... |
#80 |
George, if you have the time to look, do you think this circuit or something similar, would be OK to modify a Simple PP to fixed bias or is it just another silly idea? Thanks, Ian.
Thread | Thread Starter | Forum | Replies | Last Post |
Favorite Threads and Posts in "Pass Labs" | Variac | Pass Labs | 32 | 17th January 2018 10:03 AM |
Favorite Threads and Posts in "ESL's, Planars, Alternative Technologies" Forum | Variac | Planars & Exotics | 5 | 13th March 2010 09:23 AM |
NP:"Simple Sounds Better" TGY:"Simple Food Better" | Gyuri | The Lounge | 10 | 19th December 2009 09:03 PM |
Favorite Threads and Posts in "Electronics & Parts" | Variac | Parts | 1 | 19th July 2007 12:24 AM |
New To Site? | Need Help? |
