Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 16th November 2010, 07:27 AM   #31
Ian444 is offline Ian444  Australia
Yep, that's right, I changed the four screen resistors from 100R to 820R to clean up the sound when not using global feedback. I found 1K5 too much and 470R not enough. It may be different with your dual-driver speakers compared to my 4 ohm single driver speakers, I don't really know. Definitely worth trying though!
Old 17th November 2010, 02:26 PM   #32
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Different tubes respond differently too. I find that on my old Sylvanias the measured distortion goes up as I increase the resistor value but the sound improves, up to a point (about 470 ohms). At 390 ohms there is audible loss of punch on transients with loud music. All tests are in pentode mode with GNFB on low efficiency speakers. The good speakers aren't done yet.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 17th November 2010, 07:14 PM   #33
chrisb is offline chrisb
Well, FWIW this puppy will be running 6P14P-EV - and to start in pentode with no feedback and 820R on screens, speakers will be mid efficiency dual Mark Audio EL70s. Hopefully bench tested in the next day or so and making no smoke, just music at home by weekend.
BTW, thanks to y'all for the suggestions - this is almost as much fun as my early days on the Bottlehead and old Decware forum
kinda burnt out - taking a break
Old 17th November 2010, 07:17 PM   #34
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
You need a variac? I've got one here you can borrow.
jeff
Old 17th November 2010, 09:19 PM   #35
jeff
thanks, but not necessary - I do have my own variac, but bench testing will be at "the mountain" - where there's more thorough gear and know-how
Old 18th November 2010, 09:24 AM   #36
motosapien is offline motosapien  United States
What type of speaker did you build?
Old 18th November 2010, 04:03 PM   #37
neonthecat is offline neonthecat  Canada
neonthecat's Avatar
..... Hopefully bench tested in the next day or so and making no smoke, just music at home by weekend......
I'm sure it will be fine! In my own case, the SP-P was the first DIY amp (out of a half-dozen I've built) that worked 100% perfect at switch-on. Simple is good! Interested in hearing your impressions when it's up and running.
"We provide the music, you provide the silence." - Charles Mingus
Old 19th November 2010, 08:50 PM   #38
rather a few (mostly Fostex and Mark Audio drivers presently)
this particular amp will be used with the ones on the left - dual Mark Audio/CSS EL70 paper cones with polka dots
Old 22nd November 2010, 04:22 PM   #39
okay dokay - y'all was patient over the past couple of weeks or so it's probably time to post my initial impression
system= MacBook Pro Airplay / Airport Express Toslink / Citypulse DAC / Simple PP / Castle Microtower CSS EL70
Sovtek 5AR4 / NOS Sylvania 12AT7 / 6P15P-EV / pentode (with feedback) + a "little" help from Daniel =
input sensitivity is lower than the CCS loaded LTP in the El Cheapo variant, but tons more power, dynamic snap and low end "authority" - those 4" paper cones never sounded so big
too good to take out of the system for tweakage
nah, who'm I trying to kid - but just where to start
George, et al - thanks
Old 22nd November 2010, 07:50 PM   #40
vinylkid58's Avatar
Maybe Santa will bring you a NOS Mullard GZ34.
What are the coupling cap values? I have a hand-full of 0.22uf K40's here, they are a little on the large side physically.
Are you really using 6P15P's, or that a typo?
jeff
"favorite" outputs for Simple P/P?Hide this!Advertise here!
Favorite Threads and Posts in "Pass Labs" Variac Pass Labs 31 17th January 2017 09:30 PM
Favorite Threads and Posts in "ESL's, Planars, Alternative Technologies" Forum Variac Planars & Exotics 5 13th March 2010 10:23 AM
NP:"Simple Sounds Better" TGY:"Simple Food Better" Gyuri The Lounge 10 19th December 2009 10:03 PM
Favorite Threads and Posts in "Electronics & Parts" Variac Parts 1 19th July 2007 01:24 AM
Copyright ©1999-2017 diyAudio
