| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
Hi everyone. Does anyone know what a good replacement for the Fred DSEI12-12a diodes would be? It'll take me all day to figure out by the datasheets.
Thanks for any suggestions. |
#2 | |
#3 |
Thank you. I did search, but for some reason didn't find those threads.
I Know from when I was working on solid state stuff a while ago, that trying to garner the appropriate specs from diode datasheets does not work so well for me. I cannot wrap my head around it. |
#4 | |
All diodes will conduct if enough reverse voltage is applied. This is called the avalanche effect. If the diode structure is not uniform across the entire chip the avalanche current will flow in a small area causing damage. Zener diodes are designed to operate in reverse conduction but an ordinary diode is not. We try to specify diodes such that they will never see enough voltage to cause reverse breakdown. This is not so easy anymore. Many of us have learned about stored magnetic energy by being zapped. I learned at a very young age by measuring the field coils of several speakers with a Simpson 260. The current from the ohm meter created a magnetic field in the coil. When the current was disconnected the collapsing magnetic field created a voltage in the coil that found a discharge path through me! What does this have to do with our tube amps? Well the power transformer is a magnetic coil capable of storing energy in its core, and this energy will be released when the current is abruptly shut off. This energy has to have a path and there is a path through the tube heaters. This has worked well for years. As modern power transformers have been cost reduced the coupling between the windings isn't as good as it used to be and the leakage inductance is higher. This can cause a very short high voltage spike to appear on the high voltage winding (most inductance) as the power switch is turned off. The spike can be less than a microsecond wide and 2500 volts or more! I have measured this on a Hammond 274BX. Vintage transformers are usually much lower. This effect is magnified when a standby switch interrupts the secondary winding itself. I have seen rectifier tubes arc over when the standby switch is opened. I no longer recomment a standby switch with modern power transformers. With a big old 1N5408 diode that has several hundred pF of capacitance the spike gets absorbed. With a high speed FRED the spike blows through the silicon zapping the diode. Well it turns out that this is a problem in SMPS's too, so the diode manufacturers have specified the amount of energy that the diode can eat in a short spike. The Fairchild Stealth diodes are avalanche rated and I have never seen one blow. What happened to my FREDs? At the time the TSE and SSE's were designed the FREDs were the hot ticket. The DSEI 12-12A was a good low cost FRED that worked well in my amps. I bought 100 of them 6 years ago and to this date none of them have failed. Most of the second batch that I bought blew up in short order. Clearly something has changed. It is common for semiconductor to modify the design of a device during its production life. Higher volume devices are moved to more efficient fabs and transfered to larger wafers. The modified devices are tested to conform to the published specifications. Often large volume customers are given advanced samples of the modified devices to verify performance in their designs. Many FREDs including the DSEI12-12 are not avalanche rated so the modified devices did not violate the non spec.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#5 |
Thanks for the detailed reply.
#6 |
Hello All,
I have been a long time lurker, and have gotten some great information from all of you, but alas, it looks like my lurking days are done... I decided to finally build that Tubeleb SE that I have been eyeing for some time, I got my boards from George, (Thanks BTW) ordered my iron from Edcore, ebayed me up some tubes, but things just came to a grinding halt at digi-key. The DSEI12-12A from the parts list is on backorder for a month or so, I went over to mouser and looked for the replacement that Ty suggested and it seems they are out with a 41 week lead time listed. Does anyone have any ideas? Is there a suitable replacement availble, are there other suppliers I should check? It will probably be till the end of the year before my transformers get here, so I am not in that big of a hurry, but I am not sure I can make it 41 weeks. Any suggestions would be much appriciated. Jpeg |
#7 |
It looks like all the Fairchild rectifiers are out of stock everywhere (Mouser, Digikey, Newark). If you want something now, I guess you'll have to try a STMicro part. There's three with similar specs, but I don't know if anyone has ever tried them. Let us know how they work out?
STTH812FP STMicroelectronics Rectifiers STTH812D STMicroelectronics Rectifiers STTH812DI STMicroelectronics Rectifiers Mouser also claims to have a "new" part from Ixys. Maybe it's improved over the old version? DSEP12-12B Ixys Rectifiers |
#8 |
This part from Vishay looks interesting... cheaper too.
DTV56F-E3/45 Vishay Semiconductors Rectifiers Of course, for the final word in cheap, maybe this part is good enough? Do we really need the 8~12A current rating on these guys? Would 0.5A be enough? RGP02-20EHE3/54 Vishay Semiconductors Rectifiers |
#9 |
As with the SSE, could Jpeg just go with tube rectification for the SE until the diodes show up?
#10 |
| FRED Diode Upgrade | audioferret | Parts | 11 | 20th December 2011 01:13 PM |
| Tubelab SE vs Simple SE | Pez | Tubelab | 25 | 29th October 2011 02:16 AM |
| Is this a the correct FRED for a Simple SE? | HTFAMOUS | Tubelab | 2 | 19th May 2010 02:37 PM |
| tubelab se | DimZ | Tubelab | 58 | 20th January 2009 12:47 PM |
| Tubelab SE diode substitute | sbelyo | Tubes / Valves | 5 | 23rd April 2008 08:05 PM |
| Page generated in 0.11516 seconds (80.98% PHP - 19.02% MySQL) with 10 queries |
