| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
Just as the title states; anyone give some 809 tubes a try ? I know that this would take some work; but it seems like powerdrive would surely let the grid current flow.
#2 |
I have some 809's but I haven't tried them in the TSE yet. I have toyed with the 811A which shares the same problem, high plate resistance. I had the 811A running in the TSE a few years ago. I came to the conclusion that the 811A will not do well in SE mode without some feedback. I suspect that the 809 is similar, but haven't actually tried it. For now I have too many higher priority experiments to work on.
Both of these tubes may be viable options with speakers suitable for current drive. Both also require an external filament power supply.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#3 |
I've thought about using 811A or 572B in a Simple SE - sort of.
My thought was to build up a low power Simple SE for 6Y6, 6W6, 6V6 or something similar and use an interstage transformer insead of an OPT, then use this Simple SE to drive an 811A or 572B output stage in class A2. This would be basically the same thing as the A2 811A amp on the One Electron website. I have all of the parts save the interstage transformers, and it should be a reasonably easy project since there are similar builds already out there, but I have a lot of projects to get to before this one. Win W5JAG |
| Tubelab SE vs Simple SE | Pez | Tubelab | 25 | 29th October 2011 02:16 AM |
| Need Help with Tubelab SE | lth1 | Tubelab | 9 | 1st October 2010 09:06 PM |
| Tubelab SE for other tubes | Nikon1975 | Tubelab | 1 | 16th February 2010 05:52 PM |
| Tweaking the Tubelab SE | Nikon1975 | Tubelab | 10 | 4th February 2010 03:58 PM |
| tubelab se | DimZ | Tubelab | 58 | 20th January 2009 12:47 PM |
| Page generated in 0.07009 seconds (71.41% PHP - 28.59% MySQL) with 10 queries |
