Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 9th October 2010, 11:59 AM   #31
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
Originally Posted by sureshm View Post
For C1 the recommended part is 47uf 500V. With 500v caps harder to find, would 68uF 500v work here or would there be too much stress on the rectifier? I am thinking of using a 5AR4 rectifier.
I wouldn't. If anything, I'd rather go smaller, rather than larger. There are enough problems reported with rectifiers arc'ing. Some will survive, but you're just asking for trouble.
Old 9th October 2010, 12:05 PM   #32
sureshm is offline sureshm  Australia
Thanks SGregory and Ty.
Is it just the capacitance before the choke or resistor that matters for the max 60uF? I know 120uf is recommended to follow the 47uf and choke, so the rectifier won't be affected by this larger cap later in the circuit (or the optional motor cap?). Just trying to understand how the PS works.
Old 9th October 2010, 01:11 PM   #33
nightanole is offline nightanole  United States
Or just go solid state for the rectifier. The the cap size doesnt matter. He even has an option for it.
You are correct. The tube rec cant handle more then 60uf right off the bat. It would arc at turn on. Down the way you can add more capacitance, but with diminishing returns. You could always just pop the 68uf where the motor run cap should be and install R1 or a choke.
Old 13th October 2010, 01:34 AM   #34
Does anyone have any spare IXCP10M45S that they can ship to Australia in a padded envelope? I tried ordering that part from both Mouser and Digikey and was told that the part is restricted for export out of the US by the manufacturer.
Old 13th October 2010, 03:48 PM   #35
jrn77478 is offline jrn77478  United States
Originally Posted by Fenn View Post
Super broke. Never said I was using KT88's. Sgregory mentioned them. I'll be back on in a little bit.
FWIW, I've played with all the common tubes in my SSE, using Edcor XSE OPT's. All sound good in but the KT-88 definitely shines in UL mode when the program material demands higher volume settings. I suspect that the GX transformers would be a little bit better, but just enough to justify the extra $25 per pair. That said, most of my listening is, for reasons of domestic harmony, done at lower levels and the tubes that spend the most time in the amp are my EL-34's. This setup sounds good, so good that I've not even considered upgrading the OPT's.
Old 14th October 2010, 11:58 AM   #36
motosapien is offline motosapien  United States
I had considered using the large Edcors but I do not need an amp that goes down to 20Hz. The middle of the road GXSE series reach down to 40Hz which is a bit lower than the full range drivers (CSS EL -70)I bought for the amp reach. It struck me lately that using the X series might be great for a dedicated mid/tweet amp for bi amping an appropriate speaker set up. Going to build a set of Coniston^2's for my simple se. http://www.planet10-hifi.com/boxes-CSS.html
Old 14th October 2010, 01:42 PM   #37
just about any edcor will play down to 20-30hz regardless of model. However if you get the cheap 70hz ones, they will only play a few watts before distorting. diyaudioprojects measured the 70hz models way down since he was only pushing 1 watt
Poddwatt Class-A Stereo EL84 (6BQ5) Vacuum Tube Amplifier
Simple SE Tubelab.comHide this!Advertise here!
Electrolyticless Tubelab Simple SE nic6paul Tubelab 26 20th August 2013 12:56 PM
Tubelab Simple SE Schematic Salsero Tubelab 2 12th December 2009 12:37 AM
7027A with tubelab simple se pforeman Tubelab 10 8th November 2009 02:48 PM
Tubelab Simple SE v.2 nic6paul Tubelab 3 1st November 2009 12:59 PM
Second Tubelab Simple SE board done budmaestro Tubelab 0 24th July 2008 12:18 AM
