Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 20th August 2010, 05:57 PM   #1
tigrine is offline tigrine  Canada
tigrine's Avatar
Default A preamp with the Simple SE?
Is there an advantage to use a preamp like the Simple 5687 (diyparadise - Simple 5687-based preamp) with the Simple SE?
Old 20th August 2010, 11:03 PM   #2
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
The SSE has plenty of gain in most configs, so a preamp isn't really needed for that unless your source is unusually low. The other reason a preamp is helpful is drive, especially is you want a separate volume control.
Old 21st August 2010, 04:33 AM   #3
Default I like mine with a preamp.
I use a Mapletree 2A SE that uses 6sn7's. I like it better than the Hong Kong ebay special SMD attenuator ($25). I would like to hear what other people use. glas-ware has a nice kit attenuator I will try to put together soon.
Old 28th August 2010, 08:11 PM   #4
I have an old 2-chassis Anthem Pre-1 that is ok, so I built the Simple SE with a 12bh7a driver tube (much less gain) and no volume control... this works well. Eventually I will build a preamp and sell the Anthem, but I am sold on the drive and musicality of an active preamp, I tried the SimpleSE with and without (using foobar's volume control which I know is a handicap), and I do prefer the sound with a preamp.
However, with the stock 12at7 I think you will have too much gain in most cases.
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 03:16 AM
Using Simple SE with a preamp gasser-dude Tubelab 11 26th August 2011 04:41 PM
Tubelabs SE vs. Simple SE ?? albireo13 Tubes / Valves 16 21st February 2010 10:00 PM
Simple Simple SE questions nodiak Tubelab 57 3rd February 2010 12:02 AM
Tubelab Simple SE v.2 nic6paul Tubes / Valves 3 1st November 2009 01:59 PM
Page generated in 0.08181 seconds (68.81% PHP - 31.19% MySQL) with 10 queries
