Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 16th August 2010, 12:00 AM   #1
Default Simple SE with kt120?
You think this might work with a 400-0-400 transformer? Edcor has some nice 800vac transformers and you would get what, 25watts at least in ul mode.
Triode mode you could get 20 watts if you bumped the b+ to over 600 volts, but what to do about b+ cap selection (or even resistor selection at that voltage) and taming the driver b+ back down.
Old 16th August 2010, 12:44 AM   #2
Ty_Bower's Avatar
KT90 is the "biggest" tube I stuck in my Simple SE. Honestly, I felt it sounded a good tube but really needed more kick behind it to live up to full potential. I understand the KT120 has more in common with the KT88, only with higher dissipation limits and drive requirements. Regardless, I'd imagine my observations would apply. My power transformer is a Hammond 374BX (rated at 750VCT) and at the time I was running a moderately tame 810 ohm cathode resistance.
If you want to try KT120 I'd suggest you have plenty of volts and amps on tap. Keep an eye on the voltage ratings of the power supply caps (C1, C2) and don't forget about the cathode bypass caps (C12, C22). At high currents in the finals, you are at risk of exceeding their rating.
http://i69.photobucket.com/albums/i4...E/P1120152.jpg
Old 16th August 2010, 01:37 AM   #3
ya know i never noticed it was just a cap in the feedback network...
Old 16th August 2010, 09:12 PM   #4
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I've also run EH KT-90s in my SSE. I like to run them as triodes with the switchable bias at full tilt, which is about 100mA per plate. They seem to take it in stride. The KT-120 may be similar, but they are a bit too rich for my blood at this stage.
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 02:16 AM
Tubelabs SE vs. Simple SE ?? albireo13 Tubes / Valves 16 21st February 2010 09:00 PM
Simple Simple SE questions nodiak Tubelab 57 2nd February 2010 11:02 PM
Question for B+ in Simple SE cgian Tubelab 8 27th January 2010 05:17 PM
simple se success! newtube Tubes / Valves 3 24th May 2009 09:23 PM
Page generated in 0.07972 seconds (76.72% PHP - 23.28% MySQL) with 10 queries
