| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
#11 | |
Sorry 'bout that. No problem about the response time. I understand you have a day job, and appreciate all your work on these projects. Last edited by Anchan; 8th August 2010 at 04:43 AM. |
#12 |
I think I am going to go ahead with this project. I plan to use (2) simple SE boards, so that I have a balanced input. This will essentially be creating a PP amp from 2 boards.
I plan on using KT-88s as output tubes. I will use a single power transformer and tube rectifier to power both boards. The essential parts so far, may be: Power transformer: Hammond P-T374BX Output Transformers: Edcor CXPP25-8-5K Filter Choke:Hammond P-T159Q I do have a question about the tube rectifier as well as the final B+ voltage. I did find a few threads discussing the different tubes, but I am still unclear on which one I should use. Also, I am unclear on how much forward drop the tube rectifier will give me, and what my final B+ will end up being given a 375v transformer. Also, I am unclear on the power handling capabilities of the different tube rectifiers. Any comments on tube rectifier choice, and B+ for KT88's? I'll use this thread to post my progress. Any comments are very welcome. I work as an electronics technician by day, but this is my first tube project, so I will no doubt have some very naive questions. Last edited by Anchan; 21st August 2010 at 09:15 PM. Reason: grammatical |
#13 |
For this dual board project, and output transformers wired as George describes in post #2 of this thread, what transformers would be recommended? I plan to use KT88 tubes.
Looking at the Edcor push pull OPTs, I am thinking that an 7.6 or 8K transformer would work the best, since 1/2 of that value would be closest to the 5K OPT recommends with the single board single ended output. EDCOR - Browse Series How much headroom do I need in the wattage department? If I get 15W in triode mode, I would think a 25W OPT would be fine. Even if I run it in UL at 30W or so, I doubt I would ever really listen to louder than 20W. My speakers are 98db. Do I lose a lot of detail if I go up to 45W? I suppose my choices are: 25W, 7.6K 25W, 8K 45W, 6.6K Thanks |
#14 | |
If I am using a 360-0-360 transformer, KT88's, and a 7600 PP OPT, what value of cathode resistor would I use, if any? If I look at a design like an ST-70, their plates are connected directly together, and then through a resistor. I could not tell from your response if the plates are tied directly together, or if each tube is using an individual cathode resistor. Could you clarify this point?
Also, as I understand it, a SE design dictates that there will be a DC offset at the output, thats why we need an air gapped transformer to handle the DC. But in the case of running 2 SE in PP mode, this is no longer the case, right? I believe the answer will have something to do with the value of the cathode resistor. Could you comment on this? Quote:
#15 |
The difference between SE and PP output trannies is PP trannies don't need the gap as there are two opposing DC currents flowing through it at idle condition. You need to think of the Simple SE as a PP amp, not an SE amp, for your application. You will find it very difficult if you don't know the purpose of the cathode resistor. You may need to read/learn some more theory to pull this off. Maybe start here then read PP and triode gain stage.
#16 | |
#17 | |
No DC offset is present in the transformer if the tubes are matched. Unmatched tubes will cause a small offset, but unless they are grossly mismatched it should not be a problem. This thread has reminded me that my sound card has differential outputs. If I get some time this weekend I will try it.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#18 |
Gapped OPT of SE amp has better linearity, so that'd be a plus (if you've already owned them). Tie the secondaries of 2 SE OPT in series or parallel to get the proper ratio/load is doable (just keep them floating from ground).
So, just feed differential signal into 2 SE channels and tie them together at the output of OPT, you're done. One step further, make these 2 SE channels fed by a common HT supply, then you get a balanced and almost constant current draw throughout the whole operating range - a pure class A pp - that's one of the major philosophies of the Amity designed by Lynn Olson. ![]() I've thought about doing that for quite some time, but don't have enough amps on hand. |
#19 |
Thanks for the replies. I'll order the OPT's on Monday, then I suppose I just kick back and wait. There is about a 4 week lead time on the Edcors.
I'll solder up the boards and prepare a chassis in the meantime. |
#20 |
OK, so I have almost all the parts to put this together. I am waiting on the chassis, but I have a question about the power transformer. Remember I am using two SE boards in PP.
I have a dynakit PA060 transformer. Product Detail: PA060 POWER TRANSFORMER 360-0-360 @ 300ma. I was anticipating using KT88's. For this application I would need 4. It seems that the idle current biasing requirements are around 75-80mA. Already, I am exceeding the ratings of the transformer (80 X 4). Is this an absolute no-no? In that case, I can go with (4) EL84's instead, which I believe I would bias around 50mA, so I think I would be in OK shape. Also, I have C354 choke, which is rated at 200ma. But I figured since this is the stock choke in an ST-70, I would be alright. Thanks in advance for your responses and comments. |
| Differential push-pull design question | Tyimo | Tubes / Valves | 4 | 15th January 2010 08:05 PM |
| laying out dual output push-pull transformer? | zilog | Power Supplies | 0 | 2nd September 2008 09:50 PM |
| A push-pull differential stage- why not? | darkfenriz | Solid State | 53 | 23rd December 2007 02:00 PM |
| single cabinet...dual rlp-15's...push pull? | kramskoi | Subwoofers | 1 | 26th March 2006 12:34 PM |
| A very simple push-pull project | darkfenriz | Solid State | 5 | 6th September 2004 10:26 AM |
| Page generated in 0.14169 seconds (84.75% PHP - 15.25% MySQL) with 11 queries |
