| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
Hi Folks - I'm building SSE and TSE amps to biamp my speakers.
The SimpleSE will use Tungsol 6550s and Hammond 1628SEA OPTs to put out some ka-wump to drive the woofers. The TubelabSE will use 45's and cheapy edcor OPTs to handle frequencies above 1800Hz. I have a 400-0-400 200ma PT for the SSE and will use all off-board 440vac motor run caps, and a couple of triad C-14x chokes to drop the voltage a bit. PSUD says I should end up with about 468volts with a CLCLC arrangement. I'll add CL80/CL90s to protect the 5AR4 during startup. I've been reading Morgan Jones and trying to understand what demands a SE output tube puts on the power supply as it plays music. It's not clear in my head whether it makes much difference to dynamics and channel separation to add more capacitance across the final stage of a SE amp since the tubes are pulling about the same current whether at idle or playing music. In the interest of maximizing the dynamics and channel separation, I am thinking of separating the power supply after the initial CLC and giving each channel it's own final choke and cap (perhaps 200uF or so for each 6550). The 12AT7 CCS's could have their own final choke and cap. This adds under maybe $80 to the project using Triad chokes and ebay motor runs. (Yes, I know I might need to cut a trace on the PCB here and there and pay close attention to my wiring and grounds...) So my question is: more capacitance and isolation the merrier, or is this a noobie's waste of time?!? Another noobie question: I need to save space on one of the amps for a volume control to balance the woofers and tweeters. The tweeters are about 3dB more sensitive than the woofers. Obviously the 6550/1628SEA SSE amp running UL and CFB is going to outpower the 45 TSE, but doesn't the input sensitivity/gain (rather than power wattage) of each amp determine which one will need the volume control? I'm fuzzy on this. Anybody have any insight for me? Many thanks to George and all the wonderful contributors on this forum!! Tom |
#2 | ||||
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#3 |
George - thanks for your help!
#4 |
If you want ka-wump, you might want to consider foregoing the vacuum rectifier and go with the solid state Fairchild ISL9R8120P2 diode. And as George noted, your high voltage secondary winding is going to give an awful lot of B+. I'd think you'll be happier if you had something closer to a 320-0-320, especially if you go with SS rectification.
| Crown Studio Reference I: beefing up the power supply | elac310 | Power Supplies | 4 | 28th April 2010 12:50 AM |
| tubelab SimpleSe power transformer connection question | dubdub | Tubes / Valves | 10 | 12th September 2008 01:30 AM |
| power transformer rating and tube current - SimpleSE | cbutterworth | Tubes / Valves | 17 | 12th June 2008 10:54 PM |
| Noob Power transformer for Tubelab SimpleSE | dubdub | Tubes / Valves | 9 | 4th February 2008 08:42 PM |
| Beefing up the power supply | whitelabrat | Tubes / Valves | 9 | 16th November 2007 07:23 PM |
| Page generated in 0.10145 seconds (79.26% PHP - 20.74% MySQL) with 10 queries |
