Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 11th June 2010, 07:00 AM   #1
fandersen is offline fandersen  Canada
Default Sourcing SimpleSE parts
I'm in the process of gathering parts for my Simple SE build. I am having trouble sourcing the C1 47uF 500v capacitor. Any suggested suppliers?
Second question, is 180uF too high for C2?
Old 11th June 2010, 02:33 PM   #2
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
For 500V caps, I'd generally go with Digi-Key. Unfortunately, they are showing out of stock and estimated delivery is not until the end of July.
Old 11th June 2010, 02:41 PM   #3
skaos is offline skaos
Maybe you could try Newark...
CORNELL DUBILIER|380LX470M500J012|CAPACITOR ALUM ELECT 47UF, 500V | Newark Canada
skaos
Old 11th June 2010, 05:24 PM   #4
Thanks! probably the one place I didn't look...
Old 11th June 2010, 09:59 PM   #5
Default cathode resistors
I would like to install switchable cathode resistors, so to give me a little more room is there any reason why I should not use silicone coated wirewound resistors instead of ceramic wirewound resistors, for example digi-key 820W-5-ND vs ALSR5F-820-ND?
Old 12th June 2010, 03:53 AM   #6
Ty_Bower's Avatar
I can't think of any, as long as you stay with comparable wattage ratings. I'd think a 5 watt part is minimum.
Sourcing SimpleSE partsHide this!Advertise here!
Sourcing parts from old amps. fastasulike Solid State 2 30th November 2009 09:59 AM
Sourcing Nakamichi parts whiterabbit Car Audio 1 27th December 2007 10:05 PM
Need Help Sourcing Parts HipoFutura Solid State 10 7th December 2006 11:03 PM
sourcing parts scarole Chip Amps 0 10th May 2005 07:31 AM
Parts Sourcing philipbarrett Tubes / Valves 1 1st March 2005 05:01 AM
