Finally got to put the multi-meters on the board and power the amp up. This is my first build so was a little nervous powering it up. Thankfully, nothing happened except a slight hum from the transformer. My initial readings were -14 vdc at B+, -220 vdc at B-, and 2.48 volts at the filament. I am using this amp with some 2A3C output tubes so the filament voltage was right on. After putting in the rectifier tube B+ rose to 407 vdc. Being the voltage that the 2A3C want is in the 250 to 300 volt range, should I change C4 to a different value? If so, by how much? I am using a Triad C-14X choke in place of R-4 and using the 47uF 450V cap. in C4. Thanks,
Matt
Matt
From George's page on the TubelabSE:
Tubes and Transformers
I'd start with the recommended 4.7uF cap for C4. I think the 47uF part you have in there is too large, and my experiments with PSUDII suggest you'll hit a voltage over 350 the way you have it set up now. Something else to keep in mind - Hammonds have a reputation for running at higher than specified voltages. Perhaps this is because they are designed for 115VAC on the primary, and nobody has a line voltage that low. You might even want to start with a 4.0uF or 3.3uF cap at C4.
The 2A3 is essentially two 45's in parallel in the same envelope. The filament current is 2.5 amps per tube. The 2A3 also has a 300 volt maximum plate voltage rating, although several new production "2A3 types" have higher ratings. The higher plate current drawn by the 2A3 will bring the plate voltage to about 300 volts when used with a 550 volt transformer and a choke in place of R4. The choke should be rated for 150 to 200 mA. I use the Triad C-14X or the Hammond T193J. The B+ voltage is then fine tuned to the desired value by changing C4. Start with a very low value for C4 (4.7 uF at 450 volts) and increase if needed.
Which transformer, the output or power? If it's power, that's typical of Hammond. If it bothers you, you can try Edcor or toroidal transformer from Antek like I did.Thankfully, nothing happened except a slight hum from the transformer.
Not sure where or how I would do that. But I'm open to suggestions. My first thought (no electrical background here) is to put a non-inductive resistor between the board and the power transformer to reduce voltage, and adding a capacitor I suppose would help filtering too. Any idea how to calculate the voltage drop with a 4.7uF instead of a 47uF capacitor (Hard to find the esr value for capacitors by manufacturers)? PSUDII needs the resistance value of the capacitor to do its math.
Give your 3.3uF cap a try. Remember you won't see the actual results unless the power supply is loaded. I'll assume you're going to bias each 2A3 for 50mA, or 100mA total.
In the first image, I set the current draw to a small number (simulate the unloaded supply). I fiddled the transformer voltage until the results matched the 407V B+ you measured. In the next two images, I've set the load to 100mA and tried a 4.7uF and 3.3uF cap at the C4 position.
http://i69.photobucket.com/albums/i43/Ty_Bower/Simple SE/TubelabSE/47uF.gif
http://i69.photobucket.com/albums/i43/Ty_Bower/Simple SE/TubelabSE/47uF-1.gif
http://i69.photobucket.com/albums/i43/Ty_Bower/Simple SE/TubelabSE/33uF.gif
Hey Ty_Bower, thanks for the post with images. I didn't notice that there were two pages to the thread, and missed yours completely until I posted my findings with the 3.3 uF replacement. So, with a load, according to your image there, I should see 307 volts? That would be great. I was under the assumption that the B+ voltage during the initial check out (before output tubes, and input tubes installed, only the rectifier in) should be very close to spec. So, I should go onto the next step in the checkout with 395 volts at R30, because those volts will sag under load? Thanks for your last post!
Plugged in the output tubes, adjusted the bias current to about 55ma and watched as my voltaged dropped from 380 to about 280! Very happy that it is right where I need it now. Plugged in my cd player and, , beautiful music!!! I checked my bias current and it pretty much stayed at 55ma and my B+ voltage at about 275. Thank you all so much for your help! I know this wasn't a beginners project, but I learned a lot and now I have one hell of a tube amp. Thanks again. Picture below, and youtube clip on the way. Cheers, Matt
- More Vendors...
- Tubelab
- Going through check out Tubelab SE
