| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
Hello,
New to all of this, so bare with me. I started by soldering in the resistors today. Ordered with the parts list from the Tubelab website. I went through the board and checked all my resistor values before moving onto the next step. 5 resistors came up with different values than they were rated for: R24 should be 120k ohms... instead is 72.5k ohms R13 should be 120k ohms... instead is 72.1k oms R7 should be 100k ohms... instead is 53.9k ohms R21 should be 510 ohms... instead is 327 ohms R10 should be 510 ohms... instead is 342 ohms Is there something that I'm overlooking here? It appears that the values are half of what they are suppose to be. I have other resistors on the board, like R30 that's rated 120k ohms but read correct around 117k ohms. So, there doesn't seem to consistency other than its around half resistance on the problem resistors. Any suggestions? cheers, Matt |
#2 |
Seems like when you measure installed, you get some complex values that are due to resistors in parallel. You are not isolating the resistor alone. Take one out and check it. R30 for example has no other resistors connected both to it and ground, whereas the others do.
#3 |
As mentioned it is normal for the resistors to read different when they are connected into a complex circuit since you are measuring the entire circuit, not just the resistor. If you started with new parts there is no need to remove them again to measure them, The odds of getting a bad one are very low. If you use recycled parts it is always wise to measure before using.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#4 |
Yes, this makes sense. I'm learning a lot building this. Thanks for the help!
| Tubelab SE vs Simple SE | Pez | Tubelab | 25 | 29th October 2011 02:16 AM |
| tubelab se R3 | Nikon1975 | Tubelab | 8 | 4th March 2010 12:47 PM |
| Tubelab SE for other tubes | Nikon1975 | Tubelab | 1 | 16th February 2010 05:52 PM |
| *my* Tubelab SE build... | oldmanStrat | Tubelab | 139 | 13th July 2009 07:03 PM |
| tubelab se | DimZ | Tubelab | 58 | 20th January 2009 12:47 PM |
