Paralled output monoblock PP - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 10th May 2010, 02:45 PM   #1
adwsail is offline adwsail  United States
Default Paralled output monoblock PP
Can the simple PP output transformers outputs be paralled to create a monoblock amp in a similar fashion as the SE (not the simple SE)?
Old 10th May 2010, 05:15 PM   #2
Tubelab_com's Avatar
Yes, the inputs and outputs of both channels can simply be tied in parallel to make a mono block with one channel at twice the power. To get the power doubling you need the load impedance to be half of the impedanc of each individual channel. In other words you parallel the 16 ohm taps and connect an 8 ohm speaker. I have done this with two Simple P-P boards for a stereo amp and it works.
I then started thinking, why do I need 4 OPT's for a stereo amp? So I paralleled the output tube plates and ran them through a single OPT per board. My OPT's are large enough to support the power level. Again you need to halve the load impedance. In order to accomplish this I just connected my 8 ohm speakers to the 16 ohm taps on the OPT's. This works too, maybee even better than 4 OPT's. Your results would depend on the OPT quality.
I then started thinking about using one 12AT7 to drive all 4 output tubes. I found several ways to do this, but I must wait until I can perform some more testing to see which way works best.
I have also discovered that some EL84's and old 6BQ5's can live with a lot more than 300 volts on their plates and crank out some serious power with excellent sound, but a seperate screen regulator board is needed. These experiments must wait until I return home from a trip that I am on but I have a 100+ watt amp almost done that uses two Simple P-P boards.
The concept was proven a while back and mentioned in post # 209 and 298 here:
Tubelab Simple P-P
And # 36 here:
Pictures of your Tubelab amp
There is a discussion of an external circuit being added to SY's RLD amp in place of the bank of LED's. I am testing a version for use with the Simple P-P.
The Red Light District - another PP EL84 amp
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 10th May 2010, 05:32 PM   #3
Outstanding George, thanks alot. While I'm still chasing the unstable bias problem on my 300b SE I figured I might as well go ahead and stuff up this PP board I got from you some time ago and see how it does as a sub driver.
Monoblock design - left and right bank of output devices lae2 Solid State 3 5th March 2010 01:19 PM
KT88 PP-5 Monoblock Amplifier zcables Tubes / Valves 4 26th January 2009 06:09 PM
paralled/bridged LM3886 bojo2 Chip Amps 10 23rd November 2007 02:00 AM
EL84 PP output transformer for 6L6 PP class A engels Tubes / Valves 8 30th May 2007 09:45 AM
Paralled 4570 boards questions/help drfrink24 Chip Amps 3 1st April 2005 08:04 PM
Copyright 1999-2017 diyAudio
