| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
I'm about halfway thru my first Tubelab SE project--will build the 45 version. I have several questions.
1. Which power transformer? I have a Hammond transformer on hand (270HX; 275-0-275 @ 230 mA; 2.5-0-2.5 @3A; 3.15-0-3.15 @6A) but I'm afraid the B+ will be way too high (I would prefer to run the 45 cautiously at around 280V and 27 mA). Would appreciate advice. I know that it's over-spec'd, but might the Edcor XPWR093 (250-0-250 @300 mA; 3.15-0-3.15@7A; 5V@5A) work better? If I need to, I could order a custom power transformer from Heyboer--they quoted me a 2-3 week wait, while Edcor was more like 8-12 weeks. 2. Power supply: changing R4 to a choke and C4 I'd prefer to use a choke in place of R4. I can order either the Hammond 158M (10H; 100mA; 262 ohms) or the Triad C-14X (6H; 200mA; 150 ohms). If someone has experience as to which combination of power transformer, choke and C4 yields B+ around 280-300V, I would be most grateful to hear your recommendations. Many thanks! |
#2 |
All the best stuff comes from Chian
The Edcor is a better choice there. The Hammond 370JX is another candidate, though it would probably come in higher than spec.
For the choke, the 158M would be overloaded a bit. The 159P would be a better choice, but you can't beat the price of the Triad C-14X. |
#3 |
Thanks Russ. As the "iron" are the most expensive parts for my build, I was trying to get things "right" from the beginning.
#4 |
I should point out that Edcor is build-to-order, even if you use an existing design.
| EC52--Plate choke--300B/45/2a3/50/EL34 SE | tube-lover | Tubes / Valves | 11 | 4th October 2011 06:39 PM |
| tubelabse pt wiring | frozen wing | Tubes / Valves | 3 | 23rd May 2008 06:49 AM |
| Guitar amp PT design questions | voivodata | Tubes / Valves | 5 | 21st July 2007 07:26 AM |
| PT/OPT Orientation questions | Trout | Tubes / Valves | 5 | 17th February 2006 11:34 PM |
| Questions about a choke | TStrong_06 | Tubes / Valves | 10 | 22nd January 2003 11:19 PM |
