Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 8th April 2010, 10:33 AM   #1
Divad89 is offline Divad89  Denmark
Default Use 0,6W instead of 1/4W resistors?
I'm thinking about building a SSE, but wants to track down all the components to complete the amp before buying any of them. Because I live in Denmark I want to keep all the parts I have to buy in the US to a minimum, in a danish electronic store I've found all the resistors, but then for some reason there isn't 1/4W (for R10, R11, R12, R13, R15, R16, R19, R20, R21, R22, R23, R25, R26 and R29) but instead 0,6W, will it work or does it have to be 1/4W resistors?
David
Old 8th April 2010, 12:08 PM   #2
Shaun is online now Shaun  South Africa
Shaun's Avatar
It can have higher power ratings. Often this means a larger body size, but not always.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 8th April 2010, 02:46 PM   #3
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
George leaves ample room on the PCB for the resistors. You should have no trouble fitting 0.6W resistors. They should be precision film resistors, though, unless you are going for some particular boutique ones.
Use 0,6W instead of 1/4W resistors?Hide this!Advertise here!
6W, Class A, hopefully something I can build. :D keantoken Solid State 96 27th January 2011 12:28 PM
34k 1/4W 1% dale resistors RN60D JuanLady Parts 6 12th October 2010 10:50 PM
Fonkens and 6W - advisable? ianc13 Full Range 3 21st September 2007 06:27 PM
1/4W ,Dale resistors,help JuanLady Everything Else 2 17th June 2007 09:13 AM
