Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 4th April 2010, 02:45 PM   #1
2bz is offline 2bz  United States
Default Headphone output for tubelab simple SE amp
Greetings;
I just finished building a Tubelab Simple SE amp: 12AT7, 5AR4, and a pair of Tungsol EL34's (sweet!).
My question is: Is there a way to add a headphone output jack? If so how?
Thanks in advance.
John
Old 4th April 2010, 04:36 PM   #2
Ty_Bower's Avatar
What did you use for your output transformers? I'll assume you've got an 8 ohm secondary on them.
I'd connect an 8 ohm, 10~20 watt non-inductive cemented wirewound resistor across the OPT secondary (basically, a dummy load where the speaker would normally go). Then I'd take a 120 ohm resistor (1/2 watt will probably be fine) and wire it in series with your headphone. Put the series connected 120 ohm / headphone combo in parallel with the 8 ohm dummy load.
It'll properly load the output transformer, and keep most of the power through the dummy load so it doesn't blow your headphones (or your eardrums).
Old 4th April 2010, 05:46 PM   #3
I used Edcor GXSE15-8-5K's for OPTs. I guess I am missing the point of the 120 Ohm resistor. Would you mind drawing a schematic? Sorry for the inconvenience but I guess I "see" better than I read. Thanks.
Old 5th April 2010, 12:30 PM   #4
Ty_Bower's Avatar
Does this help?
http://i69.photobucket.com/albums/i4.../Headphone.gif
R2 is the eight ohm dummy load. It prevents the output transformer from developing damaging high voltages across the secondary, which would otherwise occur if you only had a high impedance load there.
R3 is the 120 ohm resistor. It forms a voltage divider with the headphones, reducing the delivered power to about 50 milliwatts or so. If that's not loud enough for you, trying cutting the R3 resistance in half.
R4 is where your headphone goes. I've assumed it's a common 32 ohm headphone (Sonys, Grados, etc). If it's something else, you may need to adjust values as appropriate.
Old 5th April 2010, 12:39 PM   #5
Does this help?
Perfect! Thanks for all of your help.
Old 18th January 2011, 03:18 AM   #6
Not to dig up old stuff...
My schematic for my tube amp has the output transformers listed as 4-6 ohm. I really don't see the benefit to loading these transformers ahead of a phono jack... a 120 ohm 2 watt resistor should suffice in line with the two output channels.
Electrolyticless Tubelab Simple SE nic6paul Tubelab 21 10th April 2010 08:00 PM
Tubelab Simple SE v.2 nic6paul Tubes / Valves 3 1st November 2009 12:59 PM
tubelab simple se 6.3v close to output pforeman Tubelab 3 8th August 2009 12:50 AM
Second Tubelab Simple SE board done budmaestro Tubes / Valves 0 24th July 2008 12:18 AM
Tubelab Simple SE & Edcor waam68 Tubes / Valves 2 6th March 2008 12:15 PM
Page generated in 0.09371 seconds (76.49% PHP - 23.51% MySQL) with 10 queries
