Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 31st March 2010, 06:40 PM   #1
Reidy- is offline Reidy-  United Kingdom
Default Bought my parts but missed the 1500uf 6.3v cap's will these be an alternative?
as the title says really forgot to buy the 6.3v 1500uf caps
I have used bits of an old circuit board and there are a pair of 10v 4700uf caps. obviously the voltage rating is fine but will the capacitance be too big for the transformer.
I have an edcor XPWR059
cheers, Reidy-
Old 31st March 2010, 06:57 PM   #2
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Which amp is this for? Looks like one of the cathode resistor bypass caps. Should work fine as long as they physically fit on the PCB in that location.
Old 31st March 2010, 07:24 PM   #3
its for the simple SE, I presume they are caps for the heating elements in the tubes?
Old 31st March 2010, 07:42 PM   #4
rknize's Avatar
C10 and C20? They are bypass caps for R10 and R20. Using a bigger cap here will not have any negative impact and the ones you have will work.
The only consideration is that they ought to be reasonable quality, low impedance types so that they are an effective bypass across the audio range. The parts spec'ed by George are low impedance types from Nichicon (Mouser) and Panasonic (Digikey). What you have are probably low cost, general purpose types. They will work but a better cap will sound better.
Old 1st April 2010, 06:05 PM   #5
Ok, well I needed to get a few more parts so I bought a couple of 2200uf elna caps @ 16v from world-designs.co.uk
hopefully they should suffice, will upload a picture of the built amp when its done (in the next few days hopefully.
just waiting on the coupling caps ( I bought soniq sax .47uf @ 630v) then it'll be ready to rock.
Bought my parts but missed the 1500uf 6.3v cap's will these be an alternative?Hide this!Advertise here!
Driving 3.3V parts from 5V controller jan.didden Parts 2 26th August 2008 04:23 PM
parts express alternative tareqx2 Multi-Way 7 29th August 2007 05:01 AM
Bought the kit, now I need parts systemerror909 Class D 2 5th December 2006 06:13 PM
capacitance help please- what have I missed poor_lackey Parts 4 5th December 2005 06:29 AM
Film cap's hkoetz Tubes / Valves 6 20th April 2004 05:18 AM
