Lowering B+ voltage - Page 5 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 31st May 2013, 08:11 PM   #41
ffejgo is offline ffejgo  United States
Finally put the 2.2uf cap in today. I now have 298-304v across R30. So the lower cap took care of my high voltage issue.
But...
I have a 3 way input selector switch and it didn't matter which pole was selected they were all dead quiet. Now I have a hum when no inputs are connected. The hum wasn't there previously when nothing was connected (except the speakers). All I did was swap out the 22uf for the 2.2uf cap at C4. Would the lower cap value contribute to a hum in the system?
I can live with it since on the 2 inputs I am using 1st one is quiet, the 2nd one has a very slight hum with my ear within a couple of inches and the 3rd... I can hear it from the kitchen (greater than 25feet). Could it be the switch?
I don't know why I now have a hum?? Any help is appriciated.
Thanks ahead of time for your responses.
Old 31st May 2013, 08:20 PM   #42
boywonder's Avatar
Triple check your wiring.....
Does the hum go away if you short the inputs when nothing is connected?
lowering AC heater voltage help? sbelyo Tubes / Valves 9 14th April 2008 02:28 AM
Lowering voltage output of transformer TGRANT Tubes / Valves 8 17th January 2007 11:29 AM
lowering the voltage Lowjacker Power Supplies 7 11th March 2006 10:11 AM
Help with lowering filament winding voltage. G Tubes / Valves 7 9th September 2003 12:36 AM
Lowering Supply voltage of a Toroid PaulHilgeman Solid State 13 18th February 2003 01:25 PM
Copyright 1999-2017 diyAudio
