Lowering B+ voltage - Page 4 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 16th May 2013, 01:51 PM   #31
boywonder's Avatar
Those are offloaded voltages, and will be high since they are unloaded. No need to disconnect the CT. When the amp is drawing current, the voltages will be a little lower (as you have already noticed).
37R seems reasonable.
What value caps are you using for C4 & C5?
The 560V "normal hookup" is with the amp idling with all of the tubes in place, correct?
Old 16th May 2013, 02:20 PM   #32
ffejgo is offline ffejgo  United States
C4 is 22uf
C5 is 150uf with a 80mdf Motor Run Cap in parallel
The 560v "Normal" is with the amp on and all tubes in place
Refering back to a previous question you had about changing to a 300b setup:
I think with the voltage problems I'm having with the 45's once I/we (Thank you for doing this) get it solved I'm sticking with the 45's. I can always just roll 45's. Plus the WAF is running lower. She expected Plug & Play...
Old 16th May 2013, 02:39 PM   #33
boywonder's Avatar
Here is a PSUDII model.
78ma=27ma each 45 and 12ma each 5842
Old 16th May 2013, 02:45 PM   #34
boywonder's Avatar
Lowering C4 to around 2.2uf gets B+ down to about 287V using the existing triad choke and about 280V using the Hammond 158M.....
Do you have a load resistor connected across the speaker terminals when taking the voltage measurements?
File Type: png Tubelab SE 45 PSUD (2.2uf C4+Hammond 158M).png (166.3 KB, 120 views)
Old 16th May 2013, 03:57 PM   #35
No seperate load resistor... But the speakers are connected. 8 ohm (Klipsch Forte II).
I have to admit I don't know what the "ma" numbers mean? I did attempt the PSUDII program but couldn't figure it out.
A 287v R30 with the exsiting Triad would be great. I know that if I switch the Mullard 5AR4 out with a "New" store purchased rectifier or the other one I have on hand the 287v will drop by 10v or so. It's an option??? With the numbers you gave me I'll be able to save the $23.00 on the Hammond and not have to worry about taxing my system. The PT did hum louder and get 10 degrees hotter with those 2 x 50ohm resistors in series. Although there was no hum through the speakers. I did order 2.2uf caps Just have to wait for them to arrive.
I can't begin to express how very helpfull you have been. Thank you!
Old 16th May 2013, 04:29 PM   #36
boywonder's Avatar
The load is a constant current (instead of the default resistive load in PSUD) the total current draw is:
27 ma for each 45 x 2=54 milliamps
12 ma for each 5842 x 2 = 24 milliamps
so 78ma total.
One advantage of the Hammond 158M is more henries, which will give you less hum, but if the hum is acceptable now, no worries.
Tubes have B+ "guidelines", so 270V-300V B+ is fine. The end result is the tube current times the B+ voltage roughly equals power dissipated as heat out of the tube. That's why Tubelab recommends backing off the idle current a bit when using higher B+ voltages. If you crank up the B+ and the current (within specs for the tube) the tube life will be shorter.
It's interesting that almost doubling the resistance of the choke only drops the B+ about 7V. That's because the current draw is relatively low.
Old 17th May 2013, 06:47 AM   #37
gmonno's Avatar
Hi, first of all excuse me if this is not the correct thread, but here you're talking about supply, chokes, B+, so I try to present my question.
I've just built a TSE with 300B, as choke input I used a 200mA 7H 130 Ohm.
I understand that a higher resistance will have an impact in lowering B+, and that the power (200mA) must be correctly defined to match the tube's draw.
What I don't understand clearly is how a bigger or smaller Henries will affect.
I mean, for example, what would be the difference on B+ between these two :
Hammond 193L 5H 300mA 57 Ohm
Hammond 193M 10H 300mA 63 Ohm
Many thanks
giuseppe (madrid)
Old 17th May 2013, 01:40 PM   #38
boywonder's Avatar
Many thanks
Hi: The choke current rating does not necessarily need to match the tube's draw; it needs to equal or exceed the current draw. No harm in using a higher current rated choke other than size and $$.
Using PSUD, the difference between 5H and 10H in a typical TubelabSE 300B PS is about 30mv of B+ ripple (60mv vs 30mv). The B+ voltage difference is less than a volt due to the 57 to 63 ohm DCR of the chokes.
To get the B+ ripple voltage, just take the difference between the max and min voltages in the table at the left. Note I used a 4 second delay to get on the steady-state part of the B+ curve so that the voltage has settled out.
Old 18th May 2013, 07:59 AM   #39
gmonno's Avatar
OK, understood, nearly no difference from the B+ point of view.
I change the question, what criteria will make one decide to use a 5H vs a 10H choke?
This point have never been clear even trying to read on books.
giuseppe (madrid)
Old 18th May 2013, 01:42 PM   #40
boywonder's Avatar
The PSRR (power supply rejection ratio) of the amp circuit. Circuits with high PSRR are more immune to B+ voltage ripple; ie they are less sensitive to the ripple voltage with respect to hum at the outputs (speaker terminals)......and of course $$ spent on the choke.
lowering AC heater voltage help? sbelyo Tubes / Valves 9 14th April 2008 01:28 AM
Lowering voltage output of transformer TGRANT Tubes / Valves 8 17th January 2007 10:29 AM
lowering the voltage Lowjacker Power Supplies 7 11th March 2006 09:11 AM
Help with lowering filament winding voltage. G Tubes / Valves 7 8th September 2003 11:36 PM
Lowering Supply voltage of a Toroid PaulHilgeman Solid State 13 18th February 2003 12:25 PM
Copyright 1999-2017 diyAudio
